500k Volume pot and 250k tone pot? - Telecaster Guitar Forum
Old August 26th, 2009, 02:26 PM   #1 (permalink)
cactusrob's Avatar
Will this work or will it cause some sort of time/space continuum or black hole to open up in the universe??
Are there drawbacks to this? Are there advantages? Has anybody ever done this?
I have a Di Marzio h/b designed for teles in the bridge postion and the stock s/c in the neck.
Bottom line, I'm trying to keep from re-soldering everything unless I have to...I need the 500k (I'm told) because the Di Marzio (a recent install) has a real mids/bass tone even with the tone knob on 10...
From everything I've resaerched and read, a 500k volume pot will allow more of the highs to come thru from the h/b, but do I need to replace both pots or just the volume?
Can someone steer me in the right direction? I'm semi-technical but not quite engineer level, so if you could explain it with some layman's terms, that would be cool.
Thanks
cactusrob is offline   Reply With Quote
Old August 26th, 2009, 02:48 PM   #2 (permalink)
Lerb21's Avatar
All I know is that I put a 1 meg pot in the volume in my Tele and it sounds much clearer and twangier.
You'll just need to replace the volume pot, not the tone. (to my knowledge)
I'm no engineer either.
Enforce the Thumper Doctrine
www.donrich.bravehost.com
FREE WAYLON TRIBUTE ALBUM on ReverbNation
Lerb21 is offline   Reply With Quote
Old August 26th, 2009, 05:27 PM   #3 (permalink)
Stevie 202's Avatar
Well the thing is, how does it sound to you? We are "told" we "need" 500k for a 'bucker but a lot of the time it depends on the guitar, the player, the style and the rig.
For example: I have a standard Tele that I put an SD '59 in the neck.
I tried using all 500k, and different permutations of 500s and 250s. At the end of the day I preferred all 250's.
Why?
I'm a rock/blues player and I found the 500s too brittle. Lerb is a country picker so 500s and 1Ms might be better for his style/rig.
ALSO (don't mean to be condescending) you have tone controls on your amp too.
Cheers
Stevie 202 is offline   Reply With Quote
Sponsored Links   #
Old August 26th, 2009, 05:55 PM   #4 (permalink)
cactusrob's Avatar
Thanks Lerb and Stevie for the input. I really appreciate it. Right now I'm using a Fender Pro Jr which has only volume and tone controls and I try to compensate with that as well and it sounds pretty good but it's not what I'm used to. It's kinda like you threw a blanket over the amp. I played two other guitars thru the amp the other day with no problems, so I know it's not the Jr. - It has to be the Tele (or at least the h/b)
Before the Jr, that I had a larger wattage Crate tube amp. It was really high gain and broke up early but it was the same thing. A real mid/bass tone to the guitar kinda like a blanket thrown over it.
The only solution I could find then was to incorporate a Super Overdrive, drive level down really low, adjusting the tone to a pleasing setting using the tone control on the pedal.
I'm just wondering if I need to change both pots out or if the 500K volume pot would do the trick on it's own.
Thank you again. I appreciate the advice 'cause I am by no means a tone expert.
Old August 26th, 2009, 07:25 PM   #5 (permalink)
You can use different size pots, but they both end up contributing to the tone because they are wired in parallel. I just went through this with my tele when I put a P90 in the bridge. I replaced both pots with 500k ones and it made a small difference. Then I replaced the .047uF cap with a .022 one and that made a much bigger difference. I ended up even smaller then that, with a 5000pF cap and it is about perfect to me. Some people might say the neck pup is too bright this way, but those changes only affect the treble, it still has plenty of bass. To me it sounds more focused, and has a real 'spank' to it now.
By the way, I use a ring terminal over the pots' shaft to connect all the ground wires instead of soldering to the pots' cases.
Makes the install much easier, IMO, and makes changing pots a breeze.
tjk3052 is offline   Reply With Quote
Old August 26th, 2009, 09:47 PM   #6 (permalink)
There's no "Pot Police" (not to be confused with the DEA! ). You do NOT have to have the same value tone and volume pots. If your pickups are really glassy and you want to tame them, you can shift down in tone pot value. Of course, you can always back the tone down as well, but it all depends on your style and your ears. As a general rule, the most output and highs are obtained using 1Meg pots, but the volume pot might not "taper-down" correctly with that value, and you might have to switch to 500K. It doesn't hurt to experiment freely.
[COLOR=red]John R. Frondelli[/COLOR]
"Mediocre" is the new "Good"
jrfrond is offline   Reply With Quote
Old August 26th, 2009, 10:05 PM   #7 (permalink)
Do what sounds right to you. You can use a 250K 500k or 1MEG. You can even mix them up for the volume and tone pots. In Tele's with a humbucker neck pickup I've used a 500K volume pot with a 250K tone pot.
Staggered Mag is offline   Reply With Quote
Old August 27th, 2009, 02:50 PM   #8 (permalink)
cactusrob's Avatar
I appreciate all the input.
Old August 27th, 2009, 03:11 PM   #9 (permalink)
cactusrob's Avatar
Especially the idea about using the ring terminal....good idea!
Old August 27th, 2009, 03:26 PM   #10 (permalink)
superlightweigh's Avatar
I ordered a set of four pots from Guitar Fetish to use along with two Dream 180 pups and they came that way>> two 500's and two 250's for the tone, according to their diagram. I was kinda ticked because the order sat around for many months before I got around to looking at what all came in the box.
But I digress.
I wired it up according to the diagram, and I REALLY LIKE the way it sounds! I'm gonna leave it that way.
Guitars and other Cathedrals
superlightweigh is offline   Reply With Quote
Old August 27th, 2009, 05:46 PM   #11 (permalink)
Stevie 202's Avatar
With that in mind, go ahead and experiment! That's really the only way to find out.
Cheers
Old August 29th, 2009, 12:27 PM   #12 (permalink)
chabby's Avatar
You want spank and bite with a 250K volume pot? Try a 100PF/500V Silver Mica cap on the volume side....pure Bakersfield bass bite. I just tried this new mod called the "Park Mod" on my esquire. All it is is the Eldred mod but specifically using a 100PF silver mica cap on the volume pot. I was almost in tears now having the epitamy of what the tele is all about for me. God I can't wait to bring this to the stage!
chabby is offline   Reply With Quote
Old August 29th, 2009, 04:52 PM   #13 (permalink)
Wow, what a cool idea! I've been having fits with the stupid no lead solder - the pots just don't like it!
I have a couple guitars with 500K tone pots and 250K volume pots.
I just deleted a section on why that works for me, because it is undercooked.I'll get back to ya'll.
Old August 29th, 2009, 08:31 PM   #14 (permalink)
I gotta correct myself...It was the larger pots, not the smaller cap that made the big difference in tone. When the tone and the volume are all the way up, it didn't make much of a difference what cap value I had. The cap value will make a big difference, however, once you start turning the tone down.
Old August 29th, 2009, 08:32 PM   #15 (permalink)
Any clips?
Old August 30th, 2009, 01:26 AM   #16 (permalink)
chabby's Avatar
I wish...I had to sell all my gear after a bout of unemployment. But I wish someone would try it so they could echo my experience. I described it pretty well, but to take it a step further listen to the opening intro to Gretchen Wilsons "Here for the party" it's like that. Or almost all of Pete Andersons tone on Pocket of a clown, 1000 Miles, Fast as you and did ZZ top real good too such as "Heard it on the X, La Grange. You can roll off the tone knob a bit when you need to. But it's bright but without being tinny or thin.
I'd call it very punchy and balanced. You can roll off the tone knob (I have 250K/250K) and get different tones all through its band. Very sensitive tone control this way in that rolling of a little goes a long way...but not too long...it's perfect! If your amp rig is set up right it's perfect. I'm playing through a 2 6L6 Bassman currently.
Old August 31st, 2009, 10:47 AM   #17 (permalink)
cactusrob's Avatar
So where can a fella get one of those caps? (the 100PF/500V Silver Mica, that is)
Old August 31st, 2009, 11:40 AM   #18 (permalink)
vinman's Avatar
hopefully you have a local electronics place near you other than radio shack because they don't carry it.
good news - bad news
good news, tube depot has them for 30 cents.
bad news 4 dollars shipping. they are the cheapest I have found on shipping parts, however. (it's 4 dollars no matter how many parts you order)
vinman is offline   Reply With Quote
Old September 1st, 2009, 12:16 AM   #19 (permalink)
chabby's Avatar
The Tube Depot is exactly where I bought mine!!
I totally lucked into even trying them as I had originally ordered about 10 or 12 of them for amp work. I wasn't happy with the cap tone I was getting with what I had installed when I esquired with the Eldred mod, so I just thought 100PF/500V silver micas...why not? It's what we always use on amps for bright caps....so I just tried it and I was floored.
Old September 17th, 2009, 01:22 PM   #20 (permalink)
fernando's Avatar
chabby, you mean a 100pF bleed cap on the volume pot?
fernando is offline   Reply With Quote
» Random Photo for Guests
1972 Ibanez Telecaster / Thermometer Case
» Recent ThreadsGuests
Fender Logan Custom Guitars
