Pickguard Warping On A New Tele?
Is it common for single ply pickguards to warp or pull up near the bridge pickup?
I was wondering if it's just because it's a single ply, a design flaw/poor build or if the shop doesn't have adequate humidity or something. I've seen this twice now when shopping for new Tele's. One was on a 52 AVRI with a single ply blackguard. Do the Custom Shop Nocasters have this problem as well? |
I noticed the other day that the single ply pickguard on my '50s Classic Stratocaster was humped up in front of the bridge. It's a relatively thin pickguard.
This is the most likely cause. The guitar is assembled in a relatively humid enviroment. Ensenada is on the Pacific coast. Corona is inland but gets coastal breezes. After the guitars spend some time in a dry enviroment ........ a heated store in winter or the high desert where I live, the body shrinks across the grain. The distance between the pickguard screw holes in the body gets smaller. The screw holes in the pickguard do not. Something has to give. You get a hump in the thin single ply pickguard. Simple solution............ enlarge the holes in the pickguard a little.
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
You donīt have to forget that the single-ply pickguards are fixed with 5 screws only (period-correct). So they tend to warp easier. Thatīs why Fender does fix the pickguards with 8 screws now on modern Teles, but if you want a vintage type of guitar you just have to deal with it, I guess.
Maybe you have to drill 3 extra holes, if itīs a big problem for you (but I wouldnīt do that) or put some thin double-faced adhesive tape under the pickguard. Daniel |
#5 (permalink) | |
I used the double-sided tape trick on my Esquire; on my Tele, I live with the warpage and consider it "character." |
