Grounding Problem?
Hey all,
Lately I've been having a weird buzzing problem and I can't narrow down the source. I have a highway 1 tele and I'm running it directly to a Vox AD30VT amp. When I'm plugged in and I turn on the amp it starts to buzz a bit. But as soon as I touch the strings or any metal part on the guitar, the buzzing gets a lot louder. I've tried plugging the amp into different outlets, turning off lights, computer, tv, with no improvement. I think it might be a grounding problem in the guitar but I'm not sure? Does anyone know what the source of this problem might be? Thanks for the help in advance! |
Grounding Problem
This is probably a long shot but take an aerosol can of Static Guard and spray a little Static Guard on a soft rag then wipe your pick guard with it. The problem maybe static build-up ? This is a quick trial and error thing which may or may not work. Good luck !
Glenn |
I forgot to mention to wiggle/bend both your cord jacks and see if anything happens. Also, do you have a different cord (and AMP) to try ?
It must be a wiring deal someplace as your guitar should get QUIETER when you touch any metal on it. I assume this just started ? AND, WELCOME to the forum. |
#7 (permalink) | |
I wiggled the cord jack going into the amp and if I fennegle it just right, the buzzing stops! Who thought the answer could be so easy! Does this mean that the input to my amp is loose and it just needs to be tightened? |
http://www.thefret.net/showthread.php?t=625
Another find: "The AD30VT .............Overall construction is of a very high standard with the exception of some minor design flaws, the most annoying of which would be the plastic input jack which has a tendency to work loose and drop into the amplifier chassis. " |
