Old March 4th, 2009, 12:22 AM   #1 (permalink)
Tele sounds thin. Will cap. change help?
Hey guys,
my Tele is sounding a bit thin vs. my other Teles. Just curious if changing the tone cap. (0.022uF) from the stock Am. Std. ceramic, to a say, Sprague Orange Drop cap, would fatten up the sound a bit.
And would perhaps raising the pickup heights help fatten the sound a bit?
Thanks
2002 Fender Telecaster American Std. Series / Sunburst / Maple fretbrd.
nigelcummings is offline   Reply With Quote
Old March 4th, 2009, 12:33 AM   #2 (permalink)
BritishBluesBoy's Avatar
Try changing to a .047 cap - that should make quite a difference.
BBB.
Old March 4th, 2009, 08:50 AM   #3 (permalink)
Will there be any tone shaping going from a 0.022uF to a 0.047uF cap? Because I'm just looking to fatten up the sound a bit, not change the tone. Thanks
Old March 4th, 2009, 09:06 AM   #4 (permalink)
graphs's Avatar
I don't feel that changing a tone cap is going to have a huge impact, specifically with regard to fattening up the overall sound of the guitar. It will change how the tone control responds, for sure, but not a lot else.
Have you tried raising the pickups? That would be my first course of action to beef things up.
graphs is offline   Reply With Quote
Old March 4th, 2009, 09:29 AM   #5 (permalink)
notjustdrew's Avatar
a .047 should round off some of the treble and fatten things up and upgrading to a sprague should give you a nicer tone anyway. Tone caps do effect the tone even with the tone fully open. (just changed cap on my LP and its changed it completely)
Putting the pickups closer to the strings will put the bass response up quite alot.
notjustdrew is offline   Reply With Quote
Old March 4th, 2009, 10:09 AM   #6 (permalink)
Yes it will.
BBB.
Old March 4th, 2009, 10:13 AM   #7 (permalink)
winny pooh's Avatar
In my experience a cap will make a difference so profound that its simply not worth replacing. Pickups on the other hand do make a difference, time to try a lil puncher?
Some guitars do sound thinner, they just do.
winny pooh is offline   Reply With Quote
Old March 4th, 2009, 10:35 AM   #8 (permalink)
You may experiment with upgrading to a poly cap as opposed to the ceramic. Anything over a generic poly cap is going to be nearly imperceptible. Radio Shack should have some for a buck or two...may be called a metalized film (or metal film or sometimes just film) instead of poly (or polyester).
You can order them online for MUCH cheaper, but shipping will punch you.
LocustPlague is offline   Reply With Quote
Old March 4th, 2009, 10:38 AM   #9 (permalink)
twangcaster1's Avatar
Just take the cap out and wire it straight.
Louisiana Twangmaker
twangcaster1 is offline   Reply With Quote
Old March 4th, 2009, 07:12 PM   #10 (permalink)
e-merlin's Avatar
By thin what do you mean? Does it sound weak or does it sound too bright? If it sounds weak or the output isn't up to snuff, raising the pickup should help a bunch. If it's too bright or "icepicky" you might want to lower it a bit and turn the amp up.
'tone is in the underpants'
Old March 4th, 2009, 07:19 PM   #11 (permalink)
Colt W. Knight's Avatar
I would start by raising the pickups 1/4 of a turn at a time and see if you like the results. Then I would change caps.
the now mandatory =====>
Old March 4th, 2009, 09:07 PM   #12 (permalink)
Doug Ferguson's Avatar
I use .047's in all my tele's just to fatten the tone. I prefer polyprolyne to ceramic (although technically cap material in a passive circuit does play much of a role in tone quality, though to my ears it does), so I use Orange Drops.
"If I don't like the way the times are moving I shall refuse to accompany them." -Horace Rumpole
Doug Ferguson is offline   Reply With Quote
Old March 4th, 2009, 09:18 PM   #13 (permalink)
tazzboy's Avatar
I agree try raising and lowering the pickups and see if that improves it some. If it does then problem solve. If not then try an Orange Drop .047uf Cap.
Old March 5th, 2009, 10:56 AM   #14 (permalink)
dugg's Avatar
I recently put a three way mini toggle with a 0.047pf and a 0.022pf wired so that either or both caps can be chosen into a Tele. The differences between the three settings are big. It's a great way to get familiar with the different tone curves of various capacitors. Here's a link;
http://guitarnuts2.proboards45.com/i...ay&thread=3883
"Five minutes of thought always achieves more than five minutes of work" My Mom
dugg is offline   Reply With Quote
Old March 5th, 2009, 03:40 PM   #15 (permalink)
that sounds really cool- what do you think of the difference in tone side by side?
does the .047 still have lots of twang?
Old March 5th, 2009, 04:05 PM   #16 (permalink)
PhatTele's Avatar
Nevermind...
Old March 7th, 2009, 02:22 PM   #17 (permalink)
dugg's Avatar
notjustdrew, I'm going on memory here, because I disassembled the beast last week and it's being finished now. I will say that it was only intended to be strung up for a day to test wiring, but ended up 'in the white' for over a week as various guitarists came in to spank it around. The pickup configuration on this axe is unusual. It has an angled GFS fatbody 7k very close to the bridge and a GFS alinco5 'boutique' 5.3k strat coil right next (well, as close as the 'fins' allow) to it, and no neck PU. A four way tele switch chooses; Tele, both in series, both in parallel, and Strat. Single volume, single tone with two caps and 3 way mini toggle. In the series and parallel positions the two Pups are RWRP so humbucking.
The first thing I noticed about the switch is that all four configurations react differently to the various cap combinations. For people who believe that a tone cap circuit is strictly passive and can't possibly boost any frequencies, I recommend they listen to this mod. I can't give you the electrical science behind this, but I know it has something to do with the coils acting as inductors, sort of like the gibson varitone circuits or Bill Lawrences 'resistor and cap in parallel, in series with 1.5H inductor' stuff. The middle position chooses both caps and has a very distinctive (at the risk of opening a controversial can-o-worms) 'cocked wah' sound and sounds great with just the Strat coil. The 0.047pf by itself cap is darker (counterintuitive to me because it's a higher value than both combined, ain't it?) and sounds good with both coils in series. These are just preliminary judgments. The future owner concurred that (and this guy is a players player) it would probably take him some weeks to explore the possibilities.
Old March 7th, 2009, 11:45 PM   #18 (permalink)
It is only going to make a difference if you actually use your tone control. At that point try experimenting with values over materials as that will take you a whole lot farther.
Brock Lee is offline   Reply With Quote
Old April 29th, 2009, 12:48 PM   #19 (permalink)
I partly disagree with the last comment- makes a big difference even if your tones all the way open. I tried a number of sprague caps in my tele recently and prefered the .047.
Have since put a 50s bee (0.047) in there and it made a big difference- warmer and more vocal. Highly recommend trying paper in oil caps. Did same with my LP but used luxe caps (new repros- basically russion PIO caps) and made an even bigger difference there.
So yeh- I agree experimenting with values is the more important step and the first one you should make. But once you have your value then I really wouldn't ignore materials- I've found as big a difference as between solid state and valve (really not exxagerating).
Feel free to disagree, but this is my own experience with caps.
Old April 29th, 2009, 01:18 PM   #20 (permalink)
Tom_B's Avatar
I never thought about it much... I just assumed it wouldn't make much difference, so I dismissed it. But, if you think about the fact that even when it's wide open the tone control still bleeds a fair amount of treble to ground, then changing the cap would, I guess, change what frequencies it's bleeding. It's obvious that the passive tone control wide open still effects tone when you take it out of the signal. With some pups in some configurations (pot/cap values) it's dramatic.
Tom_B is offline   Reply With Quote
