Neck Manipulation ? - Telecaster Guitar Forum
Old December 16th, 2008, 03:13 PM   #1 (permalink)
Neck Manipulation ?
Then neck I am working with seems to be as far over as possible. The strings start sliding off the neck after the 12th fret, on the Low E side. Does anyone know what to do here?
GuitarHut is offline   Reply With Quote
Old December 16th, 2008, 03:46 PM   #2 (permalink)
RIP
Steinar G's Avatar
Try loosening the screws just a little (1/4 turn), grab the neck by the headstock and yank it towards the treble side, then retighten screws. It's worked for me on a couple of guitars with a similar problem...
"Play to express, not to impress"
Website - YouTube
Steinar G is offline   Reply With Quote
Old December 16th, 2008, 05:11 PM   #3 (permalink)
The low E side, as in the one closest to the side of the neck "protected" by the pocket?
A lot of folks don't sweat that, since it means desperately needed room on the high or little E side of the board.
I suggest putting the guitar in your lap, on edge with the string facing away from your belly button and headstock off to the right. Now, loosen all 4 screws 1/4 turn, press down a little on the cutout side horn with your left hand and retighten the screws with a screwdriver in your right hand. Check it for alignment, but I'd say leave AT LEAST as much space on the little, high E side of your fingerboard where most of the playing is done.
Sponsored Links   #
» Random Photo for Guests
John Cruz Masterbuilt
» Recent ThreadsGuests
Fender Logan Custom Guitars
