ruh roh, broken neck screws... - Telecaster Guitar Forum
Old December 7th, 2008, 11:25 PM   #1 (permalink)
getbent's Avatar
I got a tele to work on... I went to remove the neck... grabbed my 18v drill and went to back out the screws.. 3 of 4 came out about a half in long! broken!
Never ever encountered this... How do I get the neck off? it is on there solid...with three of four screws...
oh holy men who call themselves tele techs... advice? drill them out?
and then...
Old December 7th, 2008, 11:27 PM   #2 (permalink)
Super Moderator
Tim Armstrong's Avatar
Ouch!
No advice from me, just...
Ouch!
Tim
Old December 7th, 2008, 11:37 PM   #3 (permalink)
voodoostation's Avatar
That's a bugger. I guess you could try an easy out. Or make you a little hole saw from some copper tubing and try to cut the wood around the screws. I'd chicken out and try the easy out.
"[COLOR="Blue"]The old worn down veterans still gather at the Hall,sitting around a table with the ghosts who gave all[/COLOR]"
http://www.ourstage.com/profile/nekkidcountry
voodoostation is offline   Reply With Quote
Sponsored Links   #
Old December 8th, 2008, 12:00 AM   #4 (permalink)
Jack Wells's Avatar
What sort (brand) of guitar is this? Normally the screw holes in the body should be sized to allow the screw to slide through freely. Doesn't sound like that's the case in your situation.
I like voodoostation's tubing idea if you can find tubing of the right diameter. I would probably use a 5/32 in. drill bit and drill down until I hit the screw then use the tubing to drill around the screw. You can get 5/32 in. brass tubing at Hobby Lobby. That should go around the screw.
5/32 = 0.15625. According to the Stratocaster blueprint found in the Duchossoir Stratocaster book the neck screw holes in the body should be 0.166 in. diameter so the 5/32 in. tubing wouldn't give you oversized holes.
Nothing fancy about making the tubing plug cutter. Just use a triangular file to file notches in the end.
Put tape on the tubing as a stop guide so you don't drill little circles in the neck.
Old December 8th, 2008, 12:07 AM   #5 (permalink)
getbent's Avatar
it is a squier from a friend's son. The screws are definitely not freely moving.. I'll get some tube tomorrow.... let no good deed go unpunished... what would have been a quick couple of mods will now be a hassle...
thanks fellers! I really appreciate it.
and then...
Old December 8th, 2008, 12:12 AM   #6 (permalink)
Colt W. Knight's Avatar
Did the forth one come out okay, and the other three just break off half way (or there abouts)?
I am with Jack, all the teles I've taken apart have had over sized holes in the body. Do you think someone put some kind of adhesive in the screw holes to get them stuck in there like that?
I've used the tubing idea on other projects, but never a guitar. I took a file and cut teeth in the end, and it worked just fine. Id say any pipe would work, not just copper, as long as it fit into the chuck of your drill.
What kind of body is it? Wood type? Finish and color?
Old December 8th, 2008, 12:21 AM   #7 (permalink)
Super Moderator
Buckocaster51's Avatar
What would Norm do?
Run a Sawz-All blade between the body and the neck...
That's what Norm would do.
But I like the tubing idea better.
Old December 8th, 2008, 12:25 AM   #8 (permalink)
Stuco's Avatar
Originally Posted by getbent View Post
... I went to remove the neck... grabbed my 18v drill...
[COLOR="LemonChiffon"]-[/COLOR]"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Old December 8th, 2008, 12:35 AM   #9 (permalink)
Originally Posted by Buckocaster51 View Post
What would Norm do?
I didn't think Norm would use something fancy and modern like sawzall blade.
Old December 8th, 2008, 12:35 AM   #10 (permalink)
getbent's Avatar
fair enough stuco, but I've done that same thing many times with no ill effects and I go slow.. they were spun before I got there... the fourth screw was a different make. My friend's kid is a tinkerer, he may have had the neck off before.... I'm gonna do the tube thing... I caught myself saying "just once I want things to go as planned," but didn't because I had about 5 things go well today..
and then...
Old December 8th, 2008, 12:45 AM   #11 (permalink)
Originally Posted by Stuco View Post
My reaction as well, but I'm thinking the damage was already done.
We need to find out a little more about the "repair history" on this guitar.
In other words, Randy, you was set up!
I can think of a dozen things I'd do to my own guitar in this instance but, given the surprises so far, I can't recommend any of them on someone else's - else's guitar.
Old December 8th, 2008, 12:48 AM   #12 (permalink)
Stuco's Avatar
lol, just joshing. Screwing really isn't dangerous with a drill I suppose (that is with guitars I mean ), if the drill is set on very low. Unscrewing with a drill is probably not dangerous at all unless you have a vintage piece that you can't risk any stripping with the original neck screws.
Old December 8th, 2008, 12:53 AM   #13 (permalink)
getbent's Avatar
I'm not gonna sweat it... I have some meetings tomorrow and a big project starting tomorrow night.. I'll get the tubing and make it in traffic and maybe tuesday night I'll tackle it... for the record, your honor, the screws offered no resistance coming out... they was gone already... ain't no thing.. I'm waiting for some left handed tuners for another guitar and I'm ready for christmas! whoa yeah!
and then...
Old December 8th, 2008, 01:03 AM   #14 (permalink)
Stuco's Avatar
Oh, and if there is some screw still sticking out then I would take a dremel tool and cut a little flathead notch in the end of the screw and well you get the idea.
Old December 8th, 2008, 01:25 AM   #15 (permalink)
getbent's Avatar
they are down there about 1/4"... I can't quite see them..
I will admit to trying to tap them out.. but they weren't budging...
and then...
Old December 8th, 2008, 01:30 AM   #16 (permalink)
Stuco's Avatar
hmm, well it sounds like that straw thing Jack recommended might be your best shot. At least this won't happen again with that body.
Old December 8th, 2008, 01:32 AM   #17 (permalink)
getbent's Avatar
exactly... it'll be a couple of days before I can tackle it.
and then...
Old December 8th, 2008, 01:49 AM   #18 (permalink)
tdowns's Avatar
So let me get this straight. You attempted to remove the neck mounting screws. Some part of the screw associated with the head of the screw broke off. So it sounds like the holes in the body are not "clearance holes" i.e, they are NOT big enough for the screw to freely glide through the hole. Because of that, they are stuck (threaded) into the body AND the neck?
If that is the case, I would drill through the holes in the body with a diameter big enough to obliterate the screw, until the neck is separated from the body. Then use jwells tubing idea to break out the screw and plug the hole with a hard wood dowel. I generally put the hardwood (oak) dowell in the drill press first and use a file edge to put groves (like threads) on the dowel. When you glue it in, the glue finds holding strength in those groves.
Good luck my man!!!!
tdowns
Old December 8th, 2008, 01:52 AM   #19 (permalink)
getbent's Avatar
Terry, you are correct. I have encountered several squiers that are very tight. When I've encountered them, I've always increased the diameter of the body holes... but, on this one.. it is as though the screws are threaded in the body...
I'm gonna give it a go.
and then...
Old December 8th, 2008, 02:09 AM   #20 (permalink)
tdowns's Avatar
For a clearance hole, a #19 drill bit should work (0.166" diameter). The next size up is a 11/64" (0.172") bit. The #8 screw is 0.164" nominal dia. Obliteration should occur.
Try to not drill all the way so the stub of a screw is sticking up out of the neck. This may allow for vise grip removal.
If you don't have anything to grab on, resolve to cutting the screw out. After you use the tubing to "break out" the screw in the neck, experiment with drilling a hole in a scrap piece of wood that is tight when driving the new hard wood dowel in it. Use that diameter for the neck. Grooves make the glue hold very good.
Am I being a jerk when I say "don't drill too deep and bust out on the front of the neck" !!! I've never done that, but it could happen so easily.
tdowns
» Random Photo for Guests
Early P and Telecaster Basses
» Recent ThreadsGuests
Fender Logan Custom Guitars
