10.5 Things I've Learned About Guitar Finishing
...the hard way of course.
1. Never think, 'the paint will cover that little blemish.' It won't, it amplifies imperfections. 2. Short cuts always take longer (true of most all phases of guitar building) 3. A proper cleaning and setup of painting workspace is well worth the time. 4. Don't hold the body in one hand, spray with the other only thinking about where to hang it once I'm done spraying. 5. Don't listen to anyone's tips that start with 'my brother-in-law paints cars and he says fill in the blank.' 6. Lacquer can react violent with previous lacquer if I've sanded the first coat through. 7. Spraying the color coat is the easy part. It is everything I've done previously that make a finish successful (or not). 8. If after I've used and cleaned the spray gun and can still tell what color I've painted it ain't clean. 9. Keep one special gun for spraying only clears because no gun is ever totally clean. 10. Do a trial fit with all pieces of the guitar while it is still in raw wood. Saves heartaches later. 10.5 No error is a mistake if I learn from it. Making the same error twice is a big mistake. Of course this thread is based on the recent likes/dislikes threads but I've been painting today and was thinking back on some of my lessons learned. Please feel free to add on. Maybe we can help each other learn something without doing it the hard way.
Turn it on, turn it up, turn me loose. Last edited by RodeoTex; December 2nd, 2008 at 08:38 PM. Reason: add |
11-I can get away with routing this direction this time(into the grain)NOT
12-Ferrule holes can not be drilled straight with a hand drill 13-If you get a foreign object in your coat,just stop,let it dry and sand it out.Don't try to "pluck" it out 14-If your router bit is getting dull,just get a new one.Sanding burn marks suck 15-No matter how careful you are,you can not do a nice job scraping binding with just a utility knife blade.Take the time and make a scraper as described by the binding masters Buckocaster and Mr Kirn I will stop there for now
Before throwing it out,make sure it's not 16x13x1.75
At my age, weight and physical condition the only running I do is when I paint.
http://www.reverbnation.com/thesmokinguns |
17. Even if the body is a rare piece of curly spalted unobtainium, find a way to make a test board for the finishing schedule.
19. Someone else will ALWAYS have a better idea
20. Work out how much color you think you'll need, then buy three times as much in the first place.....that's really the cheap part of the exercise....
Heaven: A Bassman 410, a good pizza, and a nice lie down |
Never "free sand" the wood; always block sand. Whatever kind of rustic finish you are doing, you still want it more flat as opposed to less flat. Sand ash pores lines and seam lines of all species about 15 degrees off of in-line with the pore line or seam.
When the paper stops cutting, replace it for Mercy's sake! ( That's a reminder to a guy called Bubbanov ). |
#16 (permalink) | |
So, if you keep a spray gun only for clears, how often do you clean it out? After each spraping session? As long as there is pressure from the line???
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
#17 (permalink) | |
But believe me once you clean out a gun with warm soapy water you'll want to stay with waterborne coatings. Oh, just to stay on topic: 22. Set up more lights than you thought you need so you can see the spray coming out of the gun and the gloss being laid down on the workpiece - then once you think you have enough light go and get two more lamps.
#18 (permalink) | |
Good advice, Years ago I was spraying a white strat. I was having problems because, like you said, "no gun is totally clean." After much effort, I finally got it finished, and hung it up to dry. I decided to take a cigarette break. After finishing the smoke I flicked it..............right on the white strat. Man was I mad at myself. So, you might want to add something like this: Don't flick your cigarette in the direction of a wet guitar. |
#19 (permalink) |
+ 100 on the stuff said above.
FINISHING SUCKS
Enforce the Thumper Doctrine ![]() FREE WAYLON TRIBUTE ALBUM on ReverbNation |
#20 (permalink) | |
There's a larger lesson here, folks. |
