Old February 12th, 2004, 04:47 PM   #1 (permalink)
About Neck Humbucker
Hi,
I put (this week) a neck humbucker on my Standard Telecaster. I was very dispointed with my new sound. Too many bass for my taste. I try to put a 250k resistor between the humbucker and the selector but with no good result . This evening i find the solution: i just pull down the humbucker on bass strings and pull it up on treble strings, like the bridge PU. Now it sound very well. Simple solution are often the best !
The first time i met the blues...
ArcticWhiteTelecaster is offline   Reply With Quote
Old February 12th, 2004, 07:07 PM   #2 (permalink)
So glad it worked out for you AWT!
You are correct sir! Sometimes the simple solutions prove to be the best. Now, go out there and play some blooz with that baby!
We don't stop playing because we get old, we get old becasue we stop playing.
Brad is offline   Reply With Quote
Old February 14th, 2004, 06:19 AM   #3 (permalink)
TwinReverb's Avatar
That's why...
....I got a Fralin Unbucker (7,5k). It has more clarity on the bass strings (due to uneven wound coils). It has a split coil too. Gives me 5 options.
I do have some trouble adjusting the bridgepu to match the volume of the Unbucker. I am using a Fralin Steelpole 43 for the bridge position. What are your experiences matching the two pu's ?
cheers
Erik
TwinReverb is offline   Reply With Quote
Old February 14th, 2004, 08:57 AM   #4 (permalink)
GilmourD's Avatar
Re: That's why...
cheers
Erik
My 'buckered Tele was originally a Tex Mex Tele Special. It's still got the stock Tex Mex 'bucker in the neck (cover and all) and that sounds pretty sweet, but the Tex Mex Tele bridge was a little weak comparitively. So, in went a Van Zandt Vintage Plus. I keep both pickups pretty low. The 'bucker is just high enough so that the cover "bubbles" over the guard. and the bridge pickup's a bit higher off the bridge plate (but not much). It took a bit of work, but got the things balanced and it sounds sweet. Volume-wise, the full 'bucker is still louder than the bridge, but the split 'bucker is a hair quieter than the bridge.
GilmourD is offline   Reply With Quote
Old February 17th, 2004, 05:07 PM   #5 (permalink)
TwinReverb's Avatar
hmmm, that's quite a difference
I have my HB and SP43 "floating" really high. I even "screwed up" some poles of the SP43 to get a better match with the HB. It probably kills everybody within 10 feet now I guess...
Hmmm, maybe I will try your approach GilmourD and lower them. I do like the Fralin Unbucker a lot. It has a really clear and defined bass (not muddy at all). I wouldn't mind having some Unbuckers in a LP style guitar......find one first though 8)
