Old February 2nd, 2004, 11:31 PM   #1 (permalink)
String dampener?
I need a string dampener for playing slide, but I'm not really sure how they work. I just know I need one because the noise from the strings I'm NOT playing is terrible. Not that I know how to play slide yet.
Would someone mind explaining how to put a dampener on my Tele and what's the proper dampener to use.
'From the hills they came, from backwoods without a name, carrying their guitars and a heartful of southern soul..'
OutlawSteph is offline   Reply With Quote
Old February 3rd, 2004, 05:51 PM   #2 (permalink)
Kevin's Avatar
The best "dampener" is one of your fingers behind the slide.
I'm not being facetious; that's the truth. It takes a while, but you'll get the hang of it.
Of course, I don't see anywhere in my post that says it'll actually work...
Old February 4th, 2004, 12:51 PM   #3 (permalink)
skepticult's Avatar
I'm probably worse at slide than you are, but I've read posts from people on other forums that use girl's hair "scrunchies."
Seems like it'd work.
skepticult is offline   Reply With Quote
Old February 10th, 2004, 10:35 PM   #4 (permalink)
Bluesbob's Avatar
3" length of wire
Thickness depends on string height, with insulation of course. I used to slide it down to just next to the nut, but I found that the sound was too muffled and stopped using it. Just fingers is enough and gives you a better touch.
What, me worry?
Bluesbob is offline   Reply With Quote
Old February 11th, 2004, 09:38 AM   #5 (permalink)
Scrunchies work well. They also work well if you are tying to master a two handed style of playing. I have seen Victor Wooten use them on his bass. Give it a try.
mojocaster is offline   Reply With Quote
