Old September 10th, 2008, 05:56 PM   #1 (permalink)
Finishing a guitar with poly.
I'm wondering if I should use spray on poly or brush on. Keep in mind that I do not really have the space for spraying and I'm not really good at it. Can I get a high gloss, smooth mirror finish with brush on poly if I sand and buff it right and use grain filler and sealer?
MetalKaster is offline   Reply With Quote
Old September 10th, 2008, 05:59 PM   #2 (permalink)
Yes. It will be a lot of work though. But all you'll need are some foam brushes, and a sanding block, apart from paper & polish.
Chris Leger is offline   Reply With Quote
Old September 10th, 2008, 06:15 PM   #3 (permalink)
martyb1's Avatar
Minwax wipe on poly is about the easiest to use
You can go with satin,semi-gloss or gloss
Here is Rob's how to
Wipe-On Poly
Look under info
A great resource
Before throwing it out,make sure it's not 16x13x1.75
martyb1 is offline   Reply With Quote
Old September 10th, 2008, 08:34 PM   #4 (permalink)
woodman's Avatar
thin coats will git-r-dun -- i got in trouble when i tried to lay it on too thick.
It pays to appease all the gods — Gnossos Pappadopoulis
Original tunes from the Woodshed
Old September 10th, 2008, 08:54 PM   #5 (permalink)
Colt W. Knight's Avatar
Never underestimate the time and hassle saving factor of grain filler and sealer.
