Old January 7th, 2004, 07:55 PM   #1 (permalink)
buzz feiten?
Anyone? Are they worth it or is a compensated bridge/saddles good enough?
Thanks
Fun Stuff Is Cool
klutzee is offline   Reply With Quote
Old January 8th, 2004, 10:16 AM   #2 (permalink)
The compensated saddles do
make a big difference. The Bardens are my favorite.
The Buzz system seems like more smoke and mirrors to me but I may wrong. Everytime I ask about it I never get a clear answer.
Good luck.
Spoto is offline   Reply With Quote
Old January 13th, 2004, 09:11 PM   #3 (permalink)
e-merlin's Avatar
I'm with Spoto. Compensated saddles will work. I'm not sold on the Buzz Feiten system. Anything involving the nut ceases to be effective when the string is fretted. The best remedy for intonation problems is low action and a good ear.
'tone is in the underpants'
Old January 13th, 2004, 09:31 PM   #4 (permalink)
Lyle Caldwell's Avatar
As far as nut height, you're correct. But as the Feiten system changes the lengths of the strings, it always has an effect even when fretted. A beneficial effect in my experience.
"Everybody sings about Memphis, but nobody ever does anything about it."
Lyle Caldwell is offline   Reply With Quote
Old January 13th, 2004, 09:53 PM   #5 (permalink)
Lance's Avatar
Buzz is NOT BS.
My PRSs have the Buzz system (moved nut) and all I can say is that the guitars sound MUCH more in tune than any other guitars I have....all the way up and down the neck.
Lance
Guitar Gear FAQ: Blog Facebook Page Twitter Page
Old January 14th, 2004, 07:18 AM   #6 (permalink)
Agreed.
My buddy has a custom shop Washburn shred machine that is Feitzenized, and chording on that guitar sound so beautiful and even.
Would I do it on a 3-saddle tele? No, that's already compromised.
Would I do it to a six-saddle instrument (like my Albert Lee)? Damn straight I would!
S0C7 is offline   Reply With Quote
Old January 14th, 2004, 11:14 AM   #7 (permalink)
e-merlin's Avatar
Buzz Feitin System
Just my 2c here, but doesn't the Feitin system also require compensated tuning (I think that's the term)? I'd bet (and I don't think I'm the first to say it) that most of the benefit is from the compensated tuning.
Old January 14th, 2004, 01:20 PM   #8 (permalink)
tuning
Korg makes special compensated tuner that works with Buzz system.
I'm still not convinced...
Old January 14th, 2004, 04:53 PM   #9 (permalink)
Bob Rogers's Avatar
I don't know anything specific about the Buzz Feitin system, but since you intonate after you change the nut, you are changing the distance between the bridge and the frets at the same time. So you would have a difference even on fretted notes.
Bob Rogers is offline   Reply With Quote
Old January 14th, 2004, 06:22 PM   #10 (permalink)
e-merlin's Avatar
Feitin
But that change is just moving the problem. If it works, great, I'm just saying that it probably works more because of the tuning than because of moving the nut.
Anyway, I like playing the devil's advocate.
Old January 21st, 2004, 11:09 PM   #11 (permalink)
sevenstring_slinger's Avatar
Buzz
It is 3 different things working at the same time: 1. The nut is closer--this helps the chords near the headstock. 2. You tune the guitar to an offset or compensated tuning. 3. The bridge saddles are compensated to Buzz's octave offsets--they are NOT exactly an octave higher like normal guitars.
sevenstring_slinger is offline   Reply With Quote
Old January 22nd, 2004, 04:52 AM   #12 (permalink)
hippietim's Avatar
too much thinking going on here...
If you dwell on any chord long enough it will start to go out of tune no matter what you do - it either starts out sharp or ends up flat - take your pick. Buzz Feiten and Joe Barden saddles can't fix that - they will take your money however.
I'm working on my own scheme for tuning nirvana. If you'd like to be a tester, send me your guitar, $25 + return shipping, and I'll perform my magic. I can't divulge my secrets but suffice it to say that when I'm done with your guitar that you'll be amazed with the way it stays in tune like it always has before (provided you change strings regularly and tune it normally).
My gear: http://hackolutions.com/gear.htm
My band: http://www.laughingthru.com/
hippietim is offline   Reply With Quote
Old January 22nd, 2004, 07:58 AM   #13 (permalink)
rcrecelius's Avatar
I remember reading about the Buzz Feiten thing back when it first surfaced.
In the article they mentioned the 3 things involved...
MOving the nut
Special tempered tuning and
Tempered intonation
The article went on to say that they tried several different tests to see which aspect made the most difference.
They took a guitar with a "Feitenized" nut and tuned and intonated it to standard tuning. Sounded better then usual.
Took a non feiten guitar and intonated it to Feiten specs but tuned std...also sounded better than usual.
Non feiten guitar intonated std but tuned to Feiten specs...sounded better than usual.
Then they took the Feiten guitar and did all 3 steps and this guitar sounded more in tune than all the others.
So it appears to me that while any of the 3 Feiten will yield better than std results, they claim that all 3 together is the key.
Im just mentioning the details of that article, I have never played a guitar set up this way. I have asked luthiers about giving me the tuning specs and no one would do it, thay are secretive about it. i would like to try tuning and/or intonating my guitar with Feiten specs just to see if it made a difference so if any one would like to share that information...
rcrecelius is offline   Reply With Quote
Old January 22nd, 2004, 08:49 AM   #14 (permalink)
If players tuned their own pianos, most would still be arguing that tempering is unneccesary. Feiten is really on to something.
Old January 22nd, 2004, 08:59 AM   #15 (permalink)
ComingApart's Avatar
So how exactly is the intonation set with the Feiten system? What is the tuning offset?
Or are these guarded secrets?
ComingApart is offline   Reply With Quote
Old January 22nd, 2004, 12:44 PM   #16 (permalink)
Nah, if you have your guitar "Feitenized" it comes with written offsets. Or you can buy a Korg DT-7 tuner which has a Feiten mode. You can probably find the offsets on the net.
Old January 23rd, 2004, 06:03 PM   #17 (permalink)
staxman's Avatar
Try this info
http://164.195.100.11/netacgi/nph-Pa...S=PN/6,143,966
staxman is offline   Reply With Quote
