Is there a 3-saddle 4-screw brass bridge out there?
I've searched to no avail.
I have a Bill Lawrence bridge pickup that howls like a banshee with a regular steel bridge, and sounds pretty good with the Gotoh 6-saddle brass bridge. I'd prefer 3 saddles, but (according to Becky) I have to stay away from steel bridges with this pickup. Thanks, folks! |
Not that I've seen, but those Gotoh brass bridge plates are surprisingly easy to drill your own 3-saddle holes. Just screw the plate to a big block of wood (vertically) tap some pilot holes exactly between the existing saddle screw holes, and drill away. Takes less than a few minutes. Make sure your drill bits are nice 'n sharp!
Taipantone
http://www.taipantone.com/pages/index.html
You can use a short plate, and dis-associate the bridge pup from the plate itself. You could also do it like this (self made): ![]() Or, you can buy the rigid plate from Bill Callaham and feedback will not be an issue, like it can be with a vintage $ 8 plate that isn't flat on the bottom. |
