Old July 9th, 2008, 06:52 PM   #1 (permalink)
Axtklinge's Avatar
Someone tried this "new" Dunlop StrapLok?
Hi!
First, let me clear that its been a while since I bought a straplok, so I cant realy tell how "new" this Dunlop Straplok is (its "new" for me, if you know what I mean).
Anyway, I've been using the Dunlop Tradicional Straplok system for several years now and it works just fine, and with the prospect of buy a new guitar in the horizon I did some net research for prices, and found out this "new" Dunlop Straplok...
What I wanted to know is if someone uses them, and whats your opinion.
I've only seen them in pic, and they seem very pratical, but look a bit fragile (are they made from plastic)?
Is it a safe bet, or should I just go for the more of the same "tradicional" system, and leave this modern stuff alone?
Thanks in advance for your input!
Axt
Axtklinge is offline   Reply With Quote
Old July 9th, 2008, 07:05 PM   #2 (permalink)
mellecaster's Avatar
They have been around for quite awhile..not fragile at all....work best on the Bottom Peg...install em once and forget it....not to good for those that undo em all the time though.
Old July 9th, 2008, 07:44 PM   #3 (permalink)
gibsonjunkie's Avatar
I use them on all my guitars. They work really well - not cheaply made.
The early bird gets the worm, but the second mouse gets the cheese...
gibsonjunkie is offline   Reply With Quote
Old July 9th, 2008, 09:00 PM   #4 (permalink)
Drunkinminer's Avatar
I use them too and they work well. and it allows you to keep the original strap buttons on too. highly recommoned
Drunkinminer is offline   Reply With Quote
Old July 9th, 2008, 09:12 PM   #5 (permalink)
I think these are the best strap locks available.
I used to be a big fan of Dimarzio Clip Locks, which I still am. But they look boring and I wanted a cool strap on my 52 RI. These cost me 4$ and work great.
They are very sturdy and a bit tough to get on, so they won't come off easily but I wouldn't recommend them if you like taking your strap off all the time. I don't really see any reason to spend 20 bucks on complicated metal straplocks that require new screws, will wear out and fail, and stick out from your guitar causing excess pressure.
Blonde Thinskin '59 Jazzmaster, '52 RI Tele, '66 Harmony Rocket
Silver Face Deluxe Reverb
SunFace w/ Sundial - ProCo RAT - Fulltone GT-500
Keeley AD-9 - Boss CH-1
hamish5178 is offline   Reply With Quote
Old July 9th, 2008, 09:22 PM   #6 (permalink)
There is a long thread on these over at the Rick Resource Forum.
FirstBassman is offline   Reply With Quote
Old July 9th, 2008, 10:37 PM   #7 (permalink)
pengipete's Avatar
They work fine. I just find them a bit too big with my usually skinny straps and I don't like to see a big lump of plastic when I look at my guitars.
pengipete is offline   Reply With Quote
Old July 10th, 2008, 12:42 AM   #8 (permalink)
Geoff738's Avatar
I like them.
they're kinda like a big, removable washer.
And they're cheap enough that if you buy a pair and for whatever reason you don't really like them, you haven't lost that much $$.
They work.
Cheers,
Geoff
Geoff738 is offline   Reply With Quote
Old July 10th, 2008, 02:04 AM   #9 (permalink)
boneyguy's Avatar
They've been around for many years now. They work just fine. I've also used the Dunlop Strap Lok system as well which I really like.
I am the center of the universe and so are you.
boneyguy is offline   Reply With Quote
Old July 10th, 2008, 09:58 AM   #10 (permalink)
Axtklinge's Avatar
Thank you all for your replys!
It seems they werent as new as I thought... :)
Since you all recomend them, I'm gona giv'em a try!
Cheers
Axt
Old July 10th, 2008, 10:14 AM   #11 (permalink)
Been lurking around for a while. I finally had to register to weigh in on this [and see all the great pics that hosted on site, and download the compensated nut layout tool etc.]
These look strangely like the old standby Grolsh beer bottle straplocks.
They cost $4 too, but you get to drink 2 beers...
MarkyMayhem is offline   Reply With Quote
Old July 10th, 2008, 01:27 PM   #12 (permalink)
bargoedboy's Avatar
exactly what i use on all my guitars etc , works perfect , taste all right too !
bargoedboy is offline   Reply With Quote
Old July 10th, 2008, 01:42 PM   #13 (permalink)
jholcomb's Avatar
I am a Grolsch endorser as well!
jholcomb is offline   Reply With Quote
Old July 10th, 2008, 04:43 PM   #14 (permalink)
The only difference being the dunlop is removable without taking off the strap.
Old July 10th, 2008, 04:52 PM   #15 (permalink)
Grin'n'pick's Avatar
I've 'enjoyed' the Grolsch solution myslef in the past. Work a treat, although they don't look too good on teles with a skinny vintage strap.
Grin'n'pick is offline   Reply With Quote
Old July 10th, 2008, 07:18 PM   #16 (permalink)
So do the grolsch washers...
Put the strap on over the stock buttons, then stretch the washer over the button.
-m
http://www.myspace.com/thevickroids
Old July 10th, 2008, 09:43 PM   #17 (permalink)
-m
ah, for some reason I always imagined them being pretty stiff.
Old July 11th, 2008, 10:13 AM   #18 (permalink)
Sure, but not un-workable
