Old June 14th, 2008, 10:26 AM   #1 (permalink)
chief ten beers's Avatar
Conssidering converting my hot rod 52 neck pu to single coil
Has anyone here done this and how difficult would it be to this?is it just a matter of getting a traditional tele pickguard and dropping it in or is it more involved than that?thanks
chief ten beers is offline   Reply With Quote
Old June 14th, 2008, 10:47 AM   #2 (permalink)
Why do you want to switch?
I was considering doing the opposite. . .
Blonde Thinskin '59 Jazzmaster, '52 RI Tele, '66 Harmony Rocket
Silver Face Deluxe Reverb
SunFace w/ Sundial - ProCo RAT - Fulltone GT-500
Keeley AD-9 - Boss CH-1
hamish5178 is offline   Reply With Quote
Old June 14th, 2008, 11:49 PM   #3 (permalink)
three barrel's Avatar
I was also considering doing the opposite. Every hot rod I have heard or played in the local guitar store sounded awesome in the neck position.
three barrel is offline   Reply With Quote
Old June 15th, 2008, 12:06 AM   #4 (permalink)
BritishBluesBoy's Avatar
If you do - I'll buy your pickguard off you!
BBB.
Old June 15th, 2008, 12:21 AM   #5 (permalink)
Ill trade ya for my 06 American Standard...its got single coils
CatfishStudios is offline   Reply With Quote
Old June 15th, 2008, 10:10 AM   #6 (permalink)
mellecaster's Avatar
Since no one seems to want to address your question ?...I will....If you body mount your single coil neck pup (like a regular 52ri) it will be a tad more involved (but not much)...or you can use a later style pickguard w/ the 2 holes for mounting the pup....and just use the Standard Tele wiring Diagram to check your circuit....if you have basic soldering skills, should be a piece of cake.
Old June 15th, 2008, 07:55 PM   #7 (permalink)
Robin Nahum's Avatar
I believe that the Hot Rod has different valued components in the tone circuit to achieve a better match with the two types of pickup. For instance - 375K pots rather than 250K. If this is indeed the case, changeover may be a bit more fiddly.
But I am also curious as to why one would buy a more pricey Tele and then make changes that will remove what makes it special and reduce its resale value.
RN
Robin Nahum is offline   Reply With Quote
Old June 15th, 2008, 09:26 PM   #8 (permalink)
thanks for the replies guys,i think i'm just going to keep the mimi in there after all though i may consider an antiquity in place of the stock pickup.
