Old May 3rd, 2008, 02:38 PM   #1 (permalink)
g6120's Avatar
resister value for esquire wiring
hello folks
im about to complete a esquire and i have two variations of resisters to use
one is a 330 k and the other is a 2.5 k
any difference between the two or will the 2.5 k version give my guitar a bit brighter high end with more bite .
thoughts welcomed
g6120
g6120 is offline   Reply With Quote
Old May 3rd, 2008, 03:26 PM   #2 (permalink)
Mark Davis's Avatar
Originally Posted by g6120 View Post
hello folks
thoughts welcomed
g6120
Not alot of difference really.
The best way to do this is hook up a mini pot instead of the resistor a pot is nothing more than a variable resistor so just add another pot set it for the preset bassy sound and you dont have to live with a fixed setting for the bassy sound ytou can control it.
Old May 3rd, 2008, 03:37 PM   #3 (permalink)
g6120's Avatar
hello mark
thanks for the input and while on that thought by specs which of the two ive mentioned theoredically speaking would apt to have more high end output
the 2.5k resister would let more bass end through where the 330k would take the bottom end bass off a bit more ? correct
g6120
Old May 3rd, 2008, 06:46 PM   #4 (permalink)
Mark Davis's Avatar
hello mark
g6120
The 330 is like 3.3 compared to the 2.5. I always think ther least resistance the more signal gets thru so a 2.5 should be a little brighter than the 330.
