4-way rotary switch
I'm doing a custom wiring job on a guitar and I want to use a 4-way rotary switch (http://www.allparts.com/store/4-pos-...ch,Product.asp) instead of a lever switch. I've never used a rotary switch so I'm not completely sure how to wire it. Based off of this diagram (http://deaf-eddie.net/tdpri-drawings/4-ways.jpg , the option on the right) I came up with this:
![]() I'm using only the bottom of the switch which is all I believe I need to use. Would this work? I'm not much of an electrician so I wouldn't be surprised if it's completely wrong. |
Hi,
this is my first post here. Sorry to bump this topic up, but I would like to know something about that switch. The site of allparts says it's a 4 pole switch, but I see only 2 wafers. Would it be possible to switch with this rotary, 2 humbuckers at the same time for left coil/right coil/series/parallel? |
Yup
Yes, that could be done. The switch is a stacked two-wafer switch, and each wafer has two poles. SO, you could do one pup on the top wafer, and one on the bottom; or, if it made better sense to you, you could do one pup on the two poles that are above and below each other on one semi-circular half of the switch, and the other pup on the above-and-below poles on the other side of the circle... Man, that's tough to put into words!
YMMV - I been wrong before... |
#9 (permalink) | |
3 motherbuckers by Kent Armstrong (i.e.: 3x 2 hotrails next to eachother) each in 1 triple shot (left rail, right rail, both in series, both parallel) each rail connected to the 4 way rotary for simultanious splits (outer coil, inner coil, series, parallel, for each hotrail itself!). Though the middle won't get a 4 way rotary, that will go to 2 push push pots,with this wiring, where the pots will act as master volume/tone. http://www.seymourduncan.com/support...ils_2v_2t_tspp ofcourse, there I'll only use the toggle-parts from the pots ;) I hope you understand what I mean? first the wires of the motherbuckers (4 for each hotrail, so 8 for each Motherbucker) will go to the rotary. there, from each wafer, I get 2 wires: earth and hot, those go to the triple shot ring (in fact just 2 dpdt switches in a humbucker ring), and that will finally be wired to the pickup selector what do you think of this? |
Well, it certainly seems like it will WORK...
It would probably be interesting in the bedroom, garage, or the studio, but I'd hate it when I to have to switch between two different tones, on stage, in the middle of a song, in half a bar between the vocal chorus and the guitar solo... Let us know how it turns out.
#11 (permalink) | |
#12 (permalink) | |
i want to install the rotary switch for my 4 way pickup on my tele style guitar too.i am a complete beginner in wiring and stuff. can u please briefly explain to me about the wiring procedure you did.what does input lug and hot lead mean? thanks a lot for ur time and help. Last edited by bijayandra; June 30th, 2012 at 09:30 AM. |
