Stain or Tinted Clear - Telecaster Guitar Forum
Old March 15th, 2008, 02:44 PM   #1 (permalink)
jimd's Avatar
I'm thinking about doing a build using transparent red, something like this
Since I don't have a sprayer and will use rattle cans, I think I have two options.
1) stain it red and then clear it
or
2) use the duplicolor metalcase/krylon x-metals red as a tint and clear over it once I get the look I want.
Any thoughts?
jimd is offline   Reply With Quote
Old March 15th, 2008, 03:34 PM   #2 (permalink)
I'd go with the transparent stain, of the two choices.
The red rattle cans you describe are meant to produce an opaque result. Although deep reds can take several coats to get a real even opaque coverage, I'd be expecting to get blotchy or uneven coverage, trying to use those for a trans finish. Edit: Jack says no and he knows these products better than me.
Check Mohawk, and see if they have any rattle can 'toners' you like. Their ' deep red mahogany' is quite dark, but more in the brown spectrum, not a true red.
www.mohawk-finishing.com
Old March 15th, 2008, 03:45 PM   #3 (permalink)
Stuco's Avatar
Either way should work if you take enough care. I would be sure that the clear you use is compatable with the other finishes you use though.
[COLOR="LemonChiffon"]-[/COLOR]"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Sponsored Links   #
Old March 15th, 2008, 05:33 PM   #4 (permalink)
Jack Wells's Avatar
I must respectfully disagree. Both of the above referenced reds are tinted clears. The original intention of both was to tint chrome automobile parts.
Old March 15th, 2008, 07:15 PM   #5 (permalink)
Levee_Breaker's Avatar
If it were me, I'd dye or stain the bare wood, the clearcoat it. Just make sure the dye/stain you use is compatible with whatever clearcoat you use.
Aniline dye and alcohol based stain works under anything.
Shut up and play.
Levee_Breaker is offline   Reply With Quote
Old March 15th, 2008, 07:30 PM   #6 (permalink)
Jack Wells's Avatar
I've used the ColorTone liquid dyes from StewMac mixed with alcohol. See my Thinline thread in the main forum.
Old March 15th, 2008, 08:10 PM   #7 (permalink)
Bingo. They're as good as anything, and made for the purpose.
Shut up and play.
» Random Photo for Guests
100_2091
» Recent ThreadsGuests
Fender Logan Custom Guitars
