Old March 10th, 2008, 09:16 AM   #1 (permalink)
Dion's Avatar
Static crackle from pickguard?
Hey Y'all,
Anyone here find a way to kill the pickguard static on a 4 switch wired set-up?
Cavities are all shielded and grounded. The static is pretty minimal but still there when I run my fingers across the guard.
Thanks
Dion
"Stamp Eternity on my eyeballs!" - Leonard Ravenhill
Dion is offline   Reply With Quote
Old March 10th, 2008, 09:25 AM   #2 (permalink)
voodoostation's Avatar
Most on here recommend rubbing a fabric softener sheet across the pickguard. Also get a humidifier for your room or house.
"The old worn down veterans still gather at the Hall,sitting around a table with the ghosts who gave all"
http://www.ourstage.com/profile/nekkidcountry
voodoostation is offline   Reply With Quote
Old March 10th, 2008, 09:40 AM   #3 (permalink)
Doug Ferguson's Avatar
I put some strips of copper shielding tape on the back of the guard where my fingers rub across it. No more static at all.
"If I don't like the way the times are moving I shall refuse to accompany them." -Horace Rumpole
Doug Ferguson is offline   Reply With Quote
Old March 10th, 2008, 09:43 AM   #4 (permalink)
Dion's Avatar
Fabric softener sheets, hadn't thought of that thanks
Old March 10th, 2008, 09:44 AM   #5 (permalink)
Dion's Avatar
Yeah, I've got the pickguard covered too. That knocked it down alot but not completely
Old March 10th, 2008, 10:33 AM   #6 (permalink)
endzone's Avatar
This literally drives me crazy. It seems like every guitar that I change pickups on, has this problem AFTER I change pickups, whereas the problem did not exist prior to the pup change. I even have this problem on my Casino (hollow body with a RAISED pickguard. I put aluminum shielding on it...still static. Then put copper shielding on it....still static. I haven't tried the fabric softner.
I'm Makin Progress
endzone is offline   Reply With Quote
Old March 10th, 2008, 10:41 AM   #7 (permalink)
Willie D's Avatar
I've even heard of people stuffing a Bounce sheet inside the cavity under the pickguard, but I haven't tried it myself.
"I didn't like being young. It just never appealed to me that much. I always thought the adults seemed to be having all the fun. And now I am old, and I'm having lots of fun!" - Elvis Costello
Willie D is online now   Reply With Quote
Old March 10th, 2008, 11:05 AM   #8 (permalink)
endzone's Avatar
Issue with neck pickup
Sorry, wrong thread
I'm Makin Progress
Old March 11th, 2008, 11:47 PM   #9 (permalink)
Dion's Avatar
Nutin'
Fabric softener sheet didn't do it
Anyone else wanna chime in? Help!
Old March 18th, 2008, 08:24 AM   #10 (permalink)
Static
Hi guy,s I,ve had the same prob,but used the furnace duct tape .you know the shiney stuff, well cover your pickguard with it but let it touch your neck pickups metal cover and extend the tape and lay it under your control plate to make the final ground connection.Should work cause it did for me!!!
Slydeco is offline   Reply With Quote
Old March 19th, 2008, 04:19 AM   #11 (permalink)
I had the same problem recently and used aluminum foil under the pick guard. Made a world of difference but I think the main reason for the crackling is static build up due to the dry air this time of year. I'm going to wait a couple months and remove the foil to see if the problem still exists.
Dave O is offline   Reply With Quote
Old March 19th, 2008, 04:46 AM   #12 (permalink)
Amby's Avatar
This seems to be more prevalent if you rest a finger on the pickguard whilst picking. I find that the "sheet of kitchen foil glued to back of pickguard and connected via another length of foil to under the control plate" helps quite a bit. We don't have a great deal of dry air in Scotland at this time of the year, but the static problem can still persist!
Amby is offline   Reply With Quote
