Old March 5th, 2008, 01:23 PM   #1 (permalink)
Jimo's Avatar
I always wondered....
How long will a new pack of strings last if they just set on the shelf...How long can you keep them untill they start to degrade, rust, etc....on the average...just a ballpark estimate...........thanks!---JIMO
Jimo is offline   Reply With Quote
Old March 5th, 2008, 02:07 PM   #2 (permalink)
Jack Wells's Avatar
In a dry climate my guess would be 1378 years........... but not a day more.
Old March 5th, 2008, 02:16 PM   #3 (permalink)
But only if they are in a vacuum sealed package...otherwise the humidity could cut that by a few hundred years.
blackshoe1 is offline   Reply With Quote
Old March 5th, 2008, 02:57 PM   #4 (permalink)
Jimo's Avatar
hmnnn
Well that's a pretty long time......I just found a case of strings (12 pack)--that I bought at least a year ago.....hope they work.......ha............JIMO
Old March 5th, 2008, 03:01 PM   #5 (permalink)
Togman's Avatar
I should hang on to them. You never know what a set of 'vintage' 2007 strings could be worth in a few years time!
Well it ain't the best Guitar i've ever heard, but it sounds just like it....
Togman is offline   Reply With Quote
Old March 5th, 2008, 03:05 PM   #6 (permalink)
pengipete's Avatar
It's inflation you should worry about. At 5% per annum you'll be down to 11 strings by about August.
pengipete is offline   Reply With Quote
Old March 5th, 2008, 03:15 PM   #7 (permalink)
...........but with global warming, what used to be a .010 mat really be a .011........................
cwood3 is offline   Reply With Quote
Old March 5th, 2008, 03:32 PM   #8 (permalink)
newtwanger's Avatar
Most people don't know what goes into making a set of strings, I mean it's not just straight wire and wrapped wire, there's alot of technology behind them.
I have researched and tested these for most of my life (by applying them to a testing device I call "my telecaster").
Jimo if you have 12 sets and are unsure of their "stability" I have a subterranean string testing facility (I call it "the basement") where I can hook up, say 6 sets of those strings and tell you if they do indeed meet minimum stability requirements.
Send them and any extra pickups, pickguards and amp tubes you have lying around and I'll test those too.
Anything I can do to help.
newtwanger is offline   Reply With Quote
Old March 5th, 2008, 03:42 PM   #9 (permalink)
guitarzan13's Avatar
I store mine in a Tupperware container with a bunch of silica gel packs and the keep for more than a year with NO ill effects....
Practice make permanent!!!!....Perfect practice makes perfect!!!
Chris B.
www.neonjones.com
guitarzan13 is offline   Reply With Quote
Old March 5th, 2008, 03:48 PM   #10 (permalink)
boris bubbanov's Avatar
I got one of those 25 set bulk packs from MF on the D'Addario 11-49 EXL 115s or whatever they're called. They were 'blems' because they had been in stock a while. $ 50.99 for the box, that's 2 dollars a set for the exact ones I use anyway. Perform perfectly.
Stupid stupid stupid for not getting 3-4 boxes, not a goldurned thing wrong with them except I've just about blown thru this box.
However, at the same time I also got some 10-46 D'Ad Half rounds; wow did those things ever stink for the first 2 weeks after I put them on. I wonder why?
Old March 5th, 2008, 03:49 PM   #11 (permalink)
I haven't met Newtwanger, but he sounds like a heck of a guy. Not everyone would offer what he is offering....how selfless!!!
Old March 5th, 2008, 03:54 PM   #12 (permalink)
newtwanger's Avatar
All part of being Canadian. We just give and give.
Old March 5th, 2008, 05:55 PM   #13 (permalink)
Jimo's Avatar
Thanks
Hey I appreciate the help---those strings and pickups are on their way up there---be sure and check the mail every day---and thanks again!---JIMO
