fret dressing files
i am gonna spring for some files ex stewmac
one one of these and one this for dressing fret ends of the 3 corner set which one would be most usefull?
ray |
| Sponsored Links |
For fret END dressing, if you wanna BUY all yer tooling, get ...
...6" fret leveling file trims the fret ends flush to the fingerboard edges ... ![]() ... safe edge fret end file rounds off the fret end sharp corners ... ![]() ... Micro Mesh abrasive further rounds and polishes the fret ends ...
That's fine IF you want that 35 degree "Fender" fret end angle - not for me, I want the fret ends at zero to maybe a 10 degree angle so that I get more playing surface use out of the frets/fingerboard.
If you have a table saw and a bench grinder you can make your own fret end bevel files. You could make them the angle of your choice. The bench grinder is used cut a 10 or 12 in. mill bastard file. You grind each side of the file until you're able to break it.
Jack's Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" _ ![]() Guys - learn to disable the flash on your digital cameras. |
OP, keep in mind that a lot of this is personal preference. The tools you like to use and feel comfortable with may be different than those that anyone else does.
For crowning I like the concave files as I don't trust myself to work a crown with a flat sided file without making flatspots. I have this one from StewMac with traditional file teeth, but I also found a diamond one on ebay that was even cheaper. I haven't tried it yet. ![]() I made an edge beveling file very much like the one StewMac sells. I use the file you posted for dressing the ends of the frets and like it a lot.
my blog: eryque.blogspot.com Updated 9.17.08! Subscribe_____________________
#7 (permalink) | |
i am gonna make those fret end files try a few difrent angles i also use a concave file i guess i will just get the lil fellah rob recomends
ray |
Check if you can to see if the double-sided crowning files have two different file cuts - for instance medium and fine. Some of them are the same on both sides, for instance the less expensive ones sold as a set with the colorful plastic coated handles (narrow, medium, wide) at Luthier's mercantile. The individual files at LMII have a nice hardwood handle and have two cuts - fast and slow. There's also the quarter-round file from Stew Mac which is helpful for fret ends, but can't really crown wide wire.
#10 (permalink) | |
![]() I followed Rob's lead on that file system and I've been very satisfied. The angled file makes it possible to work on guitars with non-removeable necks, so you can crown the frets near the body.
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
#12 (permalink) | |
35 minutes later I had my answer. Reminds me about the guy who broke out of prison by sawing through his cell window bars with dental floss.
