keeping lacquer out of tuner holes etc
how do you keep lacquer from dripping into the the tuner holes, screw holes etc
i hve a nice new allparts neck with neat staggered tuner holes whch i really dont want to cut out with a dill bit after the neck is sprayed with lacquer. the ferrule recesses in the body are another area where this is PIA - the bridge holes aren't on the face of the body arn't a big deal
ray |
| Sponsored Links |
On your neck, lacquer in the tuner holes shouldn't be a problem. If it's dripping in, you are spraying too wet. The spray itself doesn't actually collect that heavily inside the holes. If you're using Kluson style tuners the tuner ferrules could also be heated with a soldering iron it they won't go in easily.
Jack's Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" _ ![]() Guys - learn to disable the flash on your digital cameras. |
Sometimes it's kinda good to have a bit of lacquer in tuner holes etc because if you wet-sand the water can get into the holes and cause any unfinished wood to swell and you'll have cracks in your freshly finished guitar...
Casper: "Mmmmm. Butterscotch, yo. That's the best!" From the movie Kids |
#8 (permalink) | |
#9 (permalink) | |
its always in the back of my mind when they expand the stock may crack i feel most comfortable with a firm fit pushed in by thumb and lightly tapped home with a soft face mallet - i wll put in extra effort to achieve it cal me paranoid i dont care this tip however i would use on body ferrules no hestitation thanks for all the tips btw
ray |
Let the lacquer go in,, it'll seal the wood, then use a fine round file to gently clean the excess and slightly bevel the top of the hole just enough that the ferrules will start in the hole, Find a punch that tapers and put it in your drill press, DO NOT turn on the drill press just use it to gently press the ferrules in place,,,,piece o cake. You can do the same thing to set your string ferrules.
Keep your lamp Trimmed And Burnin Shannon, |
