Old February 7th, 2008, 10:48 AM   #1 (permalink)
5-way switch mod with "kill position"
Hi all! I have a nashville telecaster 5-way switch (just like the stratocaster one), and I would like to replace the 3-way switch on my standard telecaster with it, in order to obtain the following possibilities:
1. bridge pickup only
2. bridge and neck (parallel)
3. neck pickup only
4. bridge and neck (series)
5. kill-switch (mute signal)
Is there any mod (schematics) like that? Sorry for my inexperience (and for my english) :D
head is offline   Reply With Quote
Old February 7th, 2008, 02:45 PM   #2 (permalink)
Deaf Eddie's Avatar
The closest I can figure is:
3. neck pickup only
4. neck pickup only (REPEATS)
5. bridge and neck (series)
You'd have to get a Superswitch 5-way to get the combos you want, in the order you want them.
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
Old February 7th, 2008, 03:17 PM   #3 (permalink)
3. neck pickup only
Thanks so much Eddie, please can you give me a schematics for this configuration? Thanks again :)
Old February 7th, 2008, 03:37 PM   #4 (permalink)
Deaf Eddie's Avatar
Here's a drawing:
3. neck pickup only
The red "C" indicates the common lug for each pole.
Notice that the neck pup's ground lead goes to the common lug on the left pole, NOT to ground.
The bridge's hot is jumpered across from the bridge lug of the right pole to the "neck" lug of the left pole.
The mid and neck lugs of the right pole are jumpered together.
You will have to do the same ol' "unground/reground" of the neck pup's METAL COVER for this mod, because of the series throw.
Old February 7th, 2008, 03:44 PM   #5 (permalink)
Thank you!!! :D
Old February 8th, 2008, 10:21 AM   #6 (permalink)
Last question: will this trick works also with fender noiseless pups? Thanks.
Old February 8th, 2008, 11:26 AM   #7 (permalink)
Deaf Eddie's Avatar
Yes, It should work with ANY two pickups. The only tricky part is if the neck pup has a metal baseplate or cover, and you have the info about that.
Old February 8th, 2008, 11:57 AM   #8 (permalink)
tuuur's Avatar
3. neck pickup only
Hmmm... I got a non-fender 5-way switch in my homebuilt Tryggvecaster. I couldn't use the standard schematics because it's so different I don't know where what goes. After some trial a and erroring it ended up with the following settings:
2. bridge and neck (can't say if it's series or parallel)
3. neck pickup only
4. neck pickup only (same as 3)
I find the kill switch very handy. The dual neck pickup positions don't bother me that much.
I'll post some pics when I can.
If we all take the backseat, who's gonna drive? - Fred Cole
http://www.myspace.com/tuuur
http://www.myspace.com/daggermoon
tuuur is offline   Reply With Quote
Old February 8th, 2008, 12:18 PM   #9 (permalink)
Deaf Eddie's Avatar
3. neck pickup only
The drawing I posted will do exactly that (parallel at throw #2) if you remove the (red) jumper between the left-pole neck lug and the right-pole bridge lug, OR, remove the jumper between the mid and neck lugs on the right-pole... or do both.
I just figured four tones/no mute was better than three/with mute...
Old February 10th, 2008, 08:41 AM   #10 (permalink)
tuuur's Avatar
Ah, thanks! I'll try that out some time.
Also thanks for posting the unground/reground doc. I'd never have thought about it but that makes perfect sense.
Here's my "I don't know how to wire you" switch.
Purple wire goes to the volume pot;
Yellow wire to the bridge pickup;
Red wire to the neck pickup.
Old February 10th, 2008, 01:11 PM   #11 (permalink)
Deaf Eddie's Avatar
Here's my scheme for your switch:
Old February 10th, 2008, 01:29 PM   #12 (permalink)
Ed Bickert's Avatar
Why would you want a switch position to do what the volume knob already does? Not being a smartass, just wondering?
Sorry, not the real Ed Bickert. Just a fan.
Ed Bickert is offline   Reply With Quote
Old February 10th, 2008, 02:45 PM   #13 (permalink)
tuuur's Avatar
Deaf Eddie:
Thanks a lot!!! That's a real fast answer to that one... I definitely am going to try it.
Ed Bickert:
It won't fit in everyone's playing style, but I sometimes find it handy to very abruptly mute the sound entirely, and then just so abruptly return to the same volume you were on.
