Old February 6th, 2008, 02:57 PM   #1 (permalink)
mowcheeba's Avatar
Weight of body blank vs. final body?
Anyone know how to appreciate final weight of body from
knowing the weight of the body blank?
I have a found some old alder like wood but it seems heavy.
The body blank is 16" x 20" x 2-3/8" and weighs 17 lbs.
I know it is a bit bigger than normal body blank.
How much would a final body weigh more or less?
And if one would make a thinline how many % less weighs a
thinline body compared to a solid body?
The questions might be hard to answer but some thoughts
would be nice. Because I have no idea
mowcheeba is offline   Reply With Quote
Old February 6th, 2008, 03:55 PM   #2 (permalink)
Wild guess is less than 1/2 for your 17 pounder !
Going from 2-2/8 to 1-3/4 is a big step and then to
15-3/4 by 12-3/4 love to see what you have then?
martino is offline   Reply With Quote
Old February 6th, 2008, 04:01 PM   #3 (permalink)
here is a good link about the body size.
http://www.tdpri.com/forum/telecaste...blueprint.html
Old February 6th, 2008, 04:22 PM   #4 (permalink)
Without looking at any other post or references, I can tell you that depending on the size of the body blank, and the thickness you decide on, the weight can go down by as much as 50%, but 35% is more likely.
If weight is a concern for you (and it should be), do a semi-hollow/chambered body, it is well worth the effort!
Adios!
WildTele is offline   Reply With Quote
Old February 6th, 2008, 04:24 PM   #5 (permalink)
jwells393's Avatar
You current body blank is 760 cubic inches. 17lbs./760 cu.in. = 0.02237 lbs per cu. in.
If the blank was milled down to 16 x 12.75 x1.75 it would be 357 cu. in. and weigh 7.99 lbs. Sorry can't tell you how much weight would be lost with shaping and routing cavities.
Old February 6th, 2008, 04:26 PM   #6 (permalink)
eryque's Avatar
That one's easy. A tele body comes out to about 266 cubic inches. Your blank is 760 cubic inches. Divide weight by volume and you get .0224 lb/cu. in.
That gets you 5.95 pounds for a completed body. Ouch.
Old February 6th, 2008, 06:22 PM   #7 (permalink)
mowcheeba's Avatar
Thank you for the link. I got the blueprint already but I am going to read the thread one more time.
This guitar are going to be a Thinline, just wanted to make sure I did not end up with a 9 lbs Thinline
Thank you for your calculation, I knew you guys could figure it out.
I was hoping for less........had a 52RI body that was about 6 lbs. No fun, sold it.
As a Thinline I am hoping to get down to 3.5 - 4 lbs. Should be possible, right?
Old February 6th, 2008, 06:39 PM   #8 (permalink)
varakeef's Avatar
I just took away 0,7 kg from 2 kg body in thinline makig progress. That's about 35 percent. So if you got a 6 pound body without chambers you might end up with 3,9 lbs. Plus hardware, whatever that weigths. Edit: a pound I guess.
And neck... with tuners.
If you remove the noisy stuff inside the piano it makes a great house for a dog.
varakeef is offline   Reply With Quote
