Old February 5th, 2008, 01:52 PM   #1 (permalink)
Ten Brooks's Avatar
Easiest Possible Finish
I put together a partscaster in November and couldn't wait to finish it. I had wanted to send it to RS Guitars for a nitro finish, but they said 10-12 week wait. This is my only guitar now.
My question is what is the simplest, easiest finish I can put on it? I want to do it in white or very pale yellow in a solid color. It is a one piece ash body, not filled grain yet etc. BTW it sounds good it has a Bill Bores PW long throw b bender, and Don Mare pups. I want to keep the finish thin.
...I danced holes in my shoes. There weren't another other way to be... by Billy Joe Shaver
Ten Brooks is offline   Reply With Quote
Old February 5th, 2008, 01:57 PM   #2 (permalink)
wilkat1's Avatar
Wipe-on Poly is the easiest possible finish. It's dead simple and ready to play in a couple of days. But not for a solid color.
I would think that primer and automotive spray paint with clear coat would be the simple way to go, though it's best to let it cure a bit.
MySpace
"That number don't mean nothing to me if the guitar don't sound right." - Buddy Guy on the year a guitar was manufactured.
wilkat1 is offline   Reply With Quote
Old February 5th, 2008, 02:02 PM   #3 (permalink)
eryque's Avatar
What he said. You're gonna have to fill the grain to get it level and glossy. By the time you do the grain filling, prime, color, clear coats, then sand and polish, you're still looking at a month. If you go for wipe on poly you can have it done in a weekend.
Old February 5th, 2008, 03:49 PM   #4 (permalink)
Tedecaster's Avatar
I just finished this up in a hurry & I'm pretty happy with the finish. It's wipe-on poly with a color wash underneath.
Here's a link to the other thread (post #6) for my quickie method
Tedecaster is offline   Reply With Quote
Old February 5th, 2008, 05:42 PM   #5 (permalink)
Colin Johnston's Avatar
aww... pity you want a solid colour or I'd recommend the wax finish I used.
"on the trail of the lonesome pine... caster"
Colin Johnston is offline   Reply With Quote
Old February 5th, 2008, 05:45 PM   #6 (permalink)
wilkat1's Avatar
Ooooh, I like Tedecaster's guitar!
MySpace
Old February 5th, 2008, 06:26 PM   #7 (permalink)
this is from your other thread via the link
" The finish is pretty straight forward:
I sealed the raw wood with 2 coats of Zinsser spray-can shellac. Then 2 coats (brushed on, waited 10 mins, then wiped off) of a wash coat of white, made out of some house-brand flat white enamel & thinner (50/50 approx.) Sealed that with the spray shellac & then 3 or 4 coats of the Minwax wipe-on poly. I lightly sanded after each shellac coat & after the second coat of white.
No spray equipment & just a foam brush for the white wash. I found the gloss wipe-on poly worked better & I didn't find it overly shiny.
You could start a body one day & finish it the next if you wanted to. "
Realy nice work Tedecaster !
I just wanted to add with ash you may try EVERCOAT Z-GRIP LITE WEIGHT BODY FILLER
by thinning down the auto body filler AKA bondo with a little lacquer thinner
you speed up the dry and cure time of the filler.
to avoid loads of sanding use Cabinet Scraper after the filler gets a crust
on it.
if you can print a photo of the color at least 2 inch X 2 inch most paint
stores shood be able to get you a close match.
most stores have rustoleum PROTECTIVE ENAMEL
enamel & thinner (50/50 approx.) just like Tedecaster did ! ! !
I bet you can do it in a weekend because of the ash.
Good luck . . .
martino is online now   Reply With Quote
Old February 5th, 2008, 07:57 PM   #8 (permalink)
probably a few coats of wipe on poly. If you want it a transparent color, it works real well with dyes too. If you keep it thin it will have a very natural feel to it. especially if you don't fill the grain
ramblinmike is offline   Reply With Quote
Old February 5th, 2008, 11:11 PM   #9 (permalink)
jimd's Avatar
Wow Tedecaster, I missed your original thread. That's a sweet guitar.
Did you sand and polish the finish or did you just leave the wipe-on poly "as is"?
jimd is offline   Reply With Quote
Old February 6th, 2008, 08:55 AM   #10 (permalink)
Tedecaster's Avatar
I left it as is.
I had it pretty smooth after I sealed the color wash with shellac. The wipe-on poly goes on pretty thin & smooth, then dries quickly so there isn't too much time to get any dust, etc. stuck in it.
Old February 6th, 2008, 09:21 AM   #11 (permalink)
fivenote's Avatar
Solid color ove a one-piece ash? Think about that one. Ash is usually picked specifically for transparent finish because the grain is so nice, and one-piece is a bonus - no join lines.
Consider what tedecaster and the others are saying about the wipe-on poly. Very easy. If you want a pale yellow, use a thinned white with maybe a few drops of yellow pigment. You'll get the late 50's blonde look with the pretty grain showing through. I did something similar using sprayed-on lacquer. It took me almost 2 years because of my busy schedule and the need to find solid hours of time to setup, spray and cleanup. It turned out good, but if I had to do it again I think I'd get similar results with wipe on color and poly clear coats.
See www.frettech.com (info link). Rob documents the wipe-on poly process pretty well.
fivenote
One day I'll finally have the perfect guitar for me. That's also the day I'll get arthritis. It was a fun ride.
fivenote is offline   Reply With Quote
Old February 6th, 2008, 09:28 AM   #12 (permalink)
Tedecaster's Avatar
Mine is pine & there is more grain showing through than you can see in the pics but I think that with a nice ash body, I would go a little more transparent with the color.
Old February 9th, 2008, 03:50 PM   #13 (permalink)
Stoked's Avatar
What was the wax finish you used? That tele looks amazing!
Stoked is offline   Reply With Quote
Old February 9th, 2008, 04:40 PM   #14 (permalink)
Thanks! Here's a thread all about it...
CLICK ME!
Old February 9th, 2008, 05:29 PM   #15 (permalink)
Ed Bickert's Avatar
In the end, if you're just trying to protect the finish, any wood finish will work. Butcher's Wax will work just fine too. And Tung Oil is also another great alternative (for a natural finish).
Sorry, not the real Ed Bickert. Just a fan.
Ed Bickert is offline   Reply With Quote
