Old February 5th, 2008, 12:59 AM   #1 (permalink)
depth of pockets for hardware and neck
Does anyone know these dimensions? I have all other dimensions but these depths.
Thanks!
bamboopat is offline   Reply With Quote
Old February 5th, 2008, 03:41 AM   #2 (permalink)
Nick JD's Avatar
Thanks!
Try here.
Old February 5th, 2008, 10:15 AM   #3 (permalink)
jwells393's Avatar
Here's a direct link to the TDowns drawing.
Telecaster Drawing
Old February 5th, 2008, 11:16 AM   #4 (permalink)
Telenator's Avatar
According to the drawing, the neck pocket is 5/8" or .625" deep.
Dogs have the right idea!
Last edited by Telenator; February 5th, 2008 at 12:57 PM. Reason: To specify "neck pocket depth."
Old February 5th, 2008, 11:47 AM   #5 (permalink)
Caper's Avatar
Looking at the depth of the bridge cavity on the drawing there are 2 measurements---0.850" and 0.687"
Caper is offline   Reply With Quote
Old February 5th, 2008, 12:44 PM   #6 (permalink)
jwells393's Avatar
Good eye there Caper. The 0.850 in. is the correct depth for the bridge cavity.
Old February 5th, 2008, 10:16 PM   #7 (permalink)
tdowns's Avatar
Thank you Caper for finding that. I wish I had a prize for ya!
Thanks to jwells for alerting me to it. The 0.687 DP shouldn't even be there.
Someone else determined that the bridge pickup is slightly out of rotation. The bridge pickup slant should be 17°. The pocket is a bit rotated away from 17°. A standard Tele pickup still fits in the hole, it doesn't have as much uniform clearance around the hole. I guess I should fix both problems and make another revision.
Best regards,
