Old February 4th, 2008, 06:30 PM   #1 (permalink)
5 way switches?
I want to put a 5 way super switch into my dual humbucker tele. Will a regular 5 way super switch fit in the tele cavity or is there a special kind you have to buy?
renegadetele is offline   Reply With Quote
Old February 4th, 2008, 11:42 PM   #2 (permalink)
I'm currently putting a tele together & planned to use a 5-way switch. It's a little big and will require some modes. For mine, I think I just have to cut off the legs and solder directly on the switch board.
Go to guitarnuts.com. They have a tutorial on using a 5-way switch for a tele.
need2retire is offline   Reply With Quote
Old February 5th, 2008, 12:24 AM   #3 (permalink)
woodman's Avatar
you might hafta do a little gentle routing in your control cavity, but nothing that'll show up top. here's what i found when researching for an upcoming build:
The switch requires a minimum of 1-7/16" deep rout for adequate clearance for the wiring.
i don't know that there's a special kind of superswitch designed for retrofit. if there is, i haven't been able to find it.
BAND PAGES:
Old February 5th, 2008, 05:54 PM   #4 (permalink)
Some folks have also drilled out the rivets and removed one of the wafers for a narrower switch. 'Course this only helps if you only need two poles.
--Rob
robrohdeszudy is offline   Reply With Quote
