You'll get several answers and opinions. Generally, you can expect a somewhat louder brighter tone that ranges from hardly noticed to harsh dependent on the pickups, tone cap value and critical ear of the listener.
Use Advanced Search function to search in titles only for 500K Pot and start reading away.
Just when you think you know the answer, they change the question. -- Roddy Piper |
Did try that, but found that the tone was a little high on the treble side, and not a great sound.
Broadly speaking, the short words are the best, and the old words best of all. |
The Classic Series MIM '69 Thinline comes with 1M pots for both volume and tone, that's what Fender was using in 1969 and for a range of years around that.
Most if not all current production Squier Teles use 500k pots in both positions. Given the wiring scheme Fender has been using on Teles since late '67... I believe if you put a larger value pot in just the tone position, you could still turn it down and at some point on the control the Tele would sound just like it did with the smaller value pot at wide open (full clockwise position). The effect on volume is different, I think generally it makes the tone brighter at any volume level. The value of the tone cap in that wiring scheme also affects the tonal result. Fender usually uses a .047 or .05 value cap. Generally speaking, a smaller one like .022 will brighten the tone and a larger one like .1 will darken the tone. This is just a lame-man's answer. tdowns can explain this stuff much better. Last edited by yegbert; January 27th, 2008 at 03:48 PM. Reason: typo |
#5 (permalink) | |
I looks to me like you answered that very well. You are right-on about the tone control. Rasing the resistance of the voulme pot as you said, generally makes the tone brighter. An electrical resonance exists between the inductance of the pickup, and the capacitance of the load (the total capacitance of the amp, cable, and tone network). If you were to use let's say a 100K or lower pot, it would completely damp out the resonance. Raising it will let this resonance peak rise. The frequency of the resonance peak depends on the inductance of the pickup, and the capacitance of the load. If the resonance is in the treble region (which it most always is), you will get a more trebley sound with a 500K pot. If you like the older Ron Rich bright Tele sound, try 1 megohm pots. If you like a smoother, darker tone, the 250Ks are probably more to your liking. 500K is a nice compromise.
Best regards, Terry Downs http://terrydownsmusic.com Equine quadrupeds may be coaxed to the reference of specific gravity but may not be compelled to imbibe thereof. |
