Old January 23rd, 2008, 10:56 PM   #1 (permalink)
Trimac20's Avatar
Rewired 52 correctly, now sounds out of phase!
I rewired everything correctly, and double-checked it twice and still the middle position sounds out of phase. I.e. it has the classic nasal, strained out of phase tone and is actually SOFTER than the neck pup alone even with the pickups adjusted to the proper height. I know what out of phase sounds like because i have that feature on my other guitar. What should I do about it? Thanks
Trimac20 is offline   Reply With Quote
Old January 24th, 2008, 07:53 AM   #2 (permalink)
Lift the leads from one of the pickups and exchange positions.
Ricky D. is offline   Reply With Quote
Old January 24th, 2008, 08:47 AM   #3 (permalink)
Rob DiStefano's Avatar
When reversing Tele pup leads, be aware that it's common for the bridge pup to have a lead soldered to the bridge plate (as a ground), and the neck pup to have a lead soldered to the pup cover (also as a ground connection).
For whichever pup yer reversing the leads, that pup's cover or plate ground connection MUST be broken and moved over to the OTHER pup lead - or you and your guitar will be very unhappy campers.
Old January 24th, 2008, 04:45 PM   #4 (permalink)
Deaf Eddie's Avatar
Yeah, what Rob sez...
This LINK may help...
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
Old January 24th, 2008, 04:47 PM   #5 (permalink)
Deaf Eddie's "Tele ground schooling" is too good! - do check it out!
