Old January 21st, 2008, 08:05 PM   #1 (permalink)
I'm never going to get a kidney-routed guitar ever again.
I've been trying to wire that thing up. It is horrible. There's no space to do anything. With two pickups with their own volume and tones, I've got a grand total of nine connections to solder to ground. I'm trying to use star grounding to reduce the chance of damaging the pots by soldering fifteen billion things to them. That leaves me with 9 things to solder to this stupid ring terminal.
I'm praying that nothing goes wrong with this guitar because my control cavity is a MESS. It is horrible. I put in two push/pull pots to switch between series and parallel for the two pickups. The wires from the pickups are so flimsy. One snapped on me and I had to re-do it (fortunately that was early on). Some of the other ones I've ended up putting in angles where they're under a lot of stress. I am *this* close to throwing my guitar against a wall if one of those little suckers snaps.
I never used to think about how difficult it would be to implement a wiring scheme. I just thought up what I wanted and did it. I won't make that mistake again.
giantslayer is offline   Reply With Quote
Old January 21st, 2008, 08:12 PM   #2 (permalink)
blacklinefish's Avatar
A way around this would be to make a template out of cardboard that fits the dimensions. Pole a hole and cut a slot for any pots and switches that fit through. Then, wire up 80% of it that can be done outside the guitar, like tone caps, pot-to-pot wiring, pot-to-switch wiring, and the leads to the output jack. Then, take it off the cardboard, mount it in, and make the last few solder connections.
--gh
blacklinefish is offline   Reply With Quote
Old January 21st, 2008, 08:18 PM   #3 (permalink)
MulliganChebichev's Avatar
--gh
+1 It also reduced the risk of singeing the body.
MulliganChebichev is offline   Reply With Quote
Old January 21st, 2008, 09:02 PM   #4 (permalink)
sean79's Avatar
What's a kidney-routed guitar? Does that mean it's routed from the back so you won't need a pickguard or control plate?
sean79 is offline   Reply With Quote
Old January 21st, 2008, 09:03 PM   #5 (permalink)
jwells393's Avatar
What is a kidney-routed guitar ?
Old January 21st, 2008, 09:28 PM   #6 (permalink)
Yes. If you want to do your own wiring, those can be really bad ideas, especially if you throw in a couple push/pull pots.
Old January 21st, 2008, 10:21 PM   #7 (permalink)
I've done some work on a couple of Ibanez guitars like that.
Not much area to work in.
Steve
6942 is offline   Reply With Quote
Old January 21st, 2008, 10:23 PM   #8 (permalink)
Mark Davis's Avatar
Thats the 1st time Ive heard it called that the way I usually heard these are called back routed.
Old January 21st, 2008, 11:06 PM   #9 (permalink)
e-merlin's Avatar
How about doing the majority of the wiring outside the cavity? I also like to use a magnifying visor when I'm working in a tight area.
'tone is in the underpants'
Old January 22nd, 2008, 12:12 AM   #10 (permalink)
Mark Davis's Avatar
The way to do these is wire it all up outside the guitar and fish the shafts of the pots thru the holes in the body with dental floss.
Old January 23rd, 2008, 12:31 AM   #11 (permalink)
Got it done last night. Good grief. I stand by my statements. Eventually, I got it all done and plugged it in, only to realize that I wired the bridge vol the way i meant to wire the neck vol and vice versa (I set it up so that the neck volume is independent in the middle position and the bridge funtions as a master - very nice setup). DOH! So I had to go rewire both of them. It was very difficult. I had to solder extra bits of cable onto a few of the wires to make them long enough. Then, when I was trying to pull the volume knob off on the bridge volume so I could rotate the pot, THE DANG THING BROKE!!! The shaft came straight out! I had to pull that out and put one of the original volume pots back in.
All-in-all, I spent about 8 or 9 hours wiring that guitar yesterday. Fortunately, it all works now, and, most importantly, it's over. And it also sounds good, too.
Old January 24th, 2008, 01:20 PM   #12 (permalink)
You've discovered why Leo designed his guitars the way he did! Working in a back-routed cavity does indeed test the patience. Such instruments lend themselves to simple electronics and external soldering.
One way is good for mass production and the other way is good for MESS production.
--Rob
robrohdeszudy is offline   Reply With Quote
