Pickup wiring help
I posted this in the pickups forum but I thought I would try here as well.
I'm wiring a set of Pete Biltoft pickups into a friend's Tele. The neck pickup (a single-blade pickup) has the normal lead and ground plus a third wire that is really just the wire-mesh shielding that is twisted into a wire. Anyone know where that wire should be attached? Pete's website is down right now so I can't contact him. Thanks in advance for any help. |
The shield should go to ground.(back of a pot)
Pete didn't supply a schematics ? that surprises me... Beware tho, When you close the control casing. This shielded wire might make contact with pot / switch terminals and there will be no sound... So you want to isolate the shielding, tape maybe or shrink tubing...
Jean www.jcayer.com CC Rider pickup installation: http://www.jcayer.com/bricolages/ccriderpups.htm Luke, may the twang be with you |
