Old November 18th, 2003, 10:25 PM   #1 (permalink)
Help with Intonation Problems!
I have tried everything I can think of to find the problem and I am still puzzled.Could this be part of the problem? I noticed that the position markers are not centered between
the D & G strings like they should.The neck is on straight and I adjusted the saddles for intonation like on all my guitars.If I push the saddles to the right about 1/8 of an inch in an angle then the dots are in the middle of the G & D strings.I measured the dots to make sure they were in the center of the neck and they are.Could the nut be part of the intonation problem? I sure would appreciate any advice.
One more thing.I built this tele myself.
Ron
Ronk is offline   Reply With Quote
Old November 18th, 2003, 10:43 PM   #2 (permalink)
Lyle Caldwell's Avatar
Sounds like your bridge is misaligned. Photos?
"Everybody sings about Memphis, but nobody ever does anything about it."
Lyle Caldwell is offline   Reply With Quote
Old November 18th, 2003, 11:44 PM   #3 (permalink)
strobe tuning
are you using a strobe tuner to set the intonation on your guitar?
Strat82 is offline   Reply With Quote
