Old January 4th, 2008, 06:14 PM   #1 (permalink)
stop me before I mod again
Here's my crazy plan:
I'm considering putting in the minibucker neck and strat middle. The guitar is a CIJ '52 RI. What would I need to use for pots, impedance wise?
thanks!
Harry Stone is offline   Reply With Quote
Old January 4th, 2008, 06:33 PM   #2 (permalink)
spankdplank's Avatar
It doesn't matter. The standard 250/250k ohm pots will be fine. I would go for 500/500K, or perhaps 500/250, to brighten up the minihumbucker a bit. Generally the higher the pot value the brighter pickup will sound, but they will all work in any combination.
spankdplank is offline   Reply With Quote
Old January 4th, 2008, 06:37 PM   #3 (permalink)
Grin'n'pick's Avatar
If you're using that pickup combo aren't you tempted to go the whole hog and do Brent Mason style wiring. Terry Downs has detailed it in several posts on here.
Just a suggestion, yours sincerely,
The other Harry Stone.
Grin'n'pick is offline   Reply With Quote
Old January 4th, 2008, 06:56 PM   #4 (permalink)
Cyrithicus's Avatar
++ on the B. Mason wiring, its what you'll want out of that setup.
"When I was young, I could remember anything, whether it happened or not." --Mark Twain
Cyrithicus is offline   Reply With Quote
Old January 4th, 2008, 09:41 PM   #5 (permalink)
Old January 4th, 2008, 09:49 PM   #6 (permalink)
JohnnyCrash's Avatar
This is what I did to a MIM body, after adding a bridseye Strat neck:
I've since removed the mini's ring and installed a pearloid guard cut for a mini in the neck (I had to route the middle position hole).
With that many pickups, I'd recommend using 500k pots and using the Tone control if the bridge/middle are a bit too bright on their own.
I constantly have to remind myself I'm a grownup and it's just the internet.
Old January 4th, 2008, 10:30 PM   #7 (permalink)
And I thought Brent Mason's wiring scheme was extreme!
I know it has been said quite often but Johnny Crash you do rule.
Old January 4th, 2008, 11:55 PM   #8 (permalink)
Thanks guys, I appreciate the help. Although I've frequently been awed by Brent Mason's playing, I don't know how his wiring is set up. I'll do a search and see what's up.
JohnnyCrash, thanks for the diagram. I might go that route, too.
Old January 5th, 2008, 10:33 AM   #9 (permalink)
franchelB's Avatar
Good luck!
http://www.squierguitars.com/product...tno=0301230506
Here's a pic you can use as reference....
Feel free to visit my homepage!
http://www.myspace.com/francisbalagtas
franchelB is offline   Reply With Quote
Old January 6th, 2008, 01:13 AM   #10 (permalink)
Man, thank you very much. The only thing keeping me from doing this mod sooner was the chance I wouldn't like it and then I've modded my favorite tele for nothing. For what that Squier costs, I'm buying one of those instead.
Old January 6th, 2008, 01:46 AM   #11 (permalink)
Tele Fan's Avatar
I thought you wanted us to stop you? So quit already, jeez.
Life is better when you just make it up as you go along.
Tele Fan is offline   Reply With Quote
