Old November 17th, 2003, 12:07 PM   #1 (permalink)
Help...a scratch
AAAgh, I was replacing a bridge pickup and ran the screw driver down the front of the guitar. The scratch didn't break the polly, and you can't see it unless you get an angle on the guitar...but it is there.
Are there any good "poly" fillers or something I can do to make it more transparent. This is an AS sunburst.
No...I am really not into "the relic" look.
Thanks
"Yeap, I like the American Standard Telecaster, I can even live with one a them PCB amps, and I even use one a them mul-tie-effects things too."
Darrell is offline   Reply With Quote
Old November 17th, 2003, 12:59 PM   #2 (permalink)
Kevin's Avatar
If it's not too deep, I'd probably just rub it out with sandpaper and polishing compound. Not at the same time, mind you! :D
Old November 17th, 2003, 08:51 PM   #3 (permalink)
Ringo's Avatar
try buffing it first
I'd use some 3M Finesse it, or some of the Meguiars products, they come in different #'s , 2 being more abrasive up to #7 more of a polish.
Hand buff it, it may mostly go away, if not you can as mentioned carefully sand it with some light grade sandpaper and then try to buff it out.
I'd try rubbing it out first though.
I've done amazing things with old 70's Fenders that had lot's of wear on the poly finish.
Old November 17th, 2003, 09:58 PM   #4 (permalink)
Kevin's Avatar
Yeah, for a scratch start with the lightest abrasive (swirl remover) and work your way back through polishing compound, rubbing compound, and sandpaper until it's gone. The work your way back up to polish it.
