Old November 14th, 2003, 05:40 PM   #1 (permalink)
cmaccall's Avatar
Question about fret buzz...
Ah fret buzz, why must you always return to haunt me...
I was setting up my MIM Standard Tele with heavier strings (10-52, versus the stock 9-42 or whatever) and encountered an odd problem with fret buzz. I am getting a fairly heavy fret buzz on the A string when fretted (the entire length of the fretboard) but not when open. The saddle height doesn't seem to make a difference and neither does the neck relief, the buzz remains. Any thoughts? Could this be the nut slot needing recutting for the heavier string and a proper break angle? Thanks for your thoughts.
cmaccall is offline   Reply With Quote
Old November 14th, 2003, 06:16 PM   #2 (permalink)
Dennis_UK's Avatar
Can't imagine it's a nut problem...
...when the buzz is only present on fretted notes. High fret right at the body end? Something on the saddle that starts a buzz only when the string is angled down by fretting? Suppose this one could be made worse with a bigger angle, ie if the string wasn't sitting in the nut slot correctly as you first said. Hmmmm...
Just guesses, there are far more kernowkedgeable folk around...
Fender MIM Precision, all black, 2004.
Fender MIJ Precision, '51 RI, Butterscotch, 1996.
Squier VM Precision TB, 3TS, 2007
Markbass CMD121H 1x12 combo plus 1x12 ext cab
My band: The Rock'nRoll Outlaws
Dennis_UK is offline   Reply With Quote
Old November 14th, 2003, 06:51 PM   #3 (permalink)
cmaccall's Avatar
Oh and...
I forgot to mention: wherever I fret the A string it has plenty of clearance over the next fret, so I don't understand where the buzz is coming from, unless it is from the frets behind where it is fretted... which it could be. The action is medium/high right now.
Old November 14th, 2003, 09:52 PM   #4 (permalink)
all over the fretboard?
does this happen all over the fretboard or just in a particular area?
there could be one or two frets that are high, and i might just be very hard to tell
i'm sure kevin can give you some good advice.
Strat82 is offline   Reply With Quote
Old November 15th, 2003, 09:47 AM   #5 (permalink)
If that was sitting on my bench, I'd probably hook up a multimeter to it. Putting one clip on the A string behind the nut, then touching the other probe/clip to each fret, while plucking the string. Probably in the playing position ( I got jigs that hold it that way ). Then maybe, I'd hear the multimeter "beep" at a certain fret or frets.
I'd also use various straight edges to see if I can do a little rocking.
You might also just want to put a different A string on and see what happens. Strings are pretty cheap, so they are sometimes defective.
Soapbarstrat is offline   Reply With Quote
