Old November 14th, 2007, 02:13 PM   #1 (permalink)
guitarzan13's Avatar
Crowning File Advise Needed
I am looking at a crowning file online.
It says that the crowning radius is .05". Will this work on medium fretwire or just narrow??
Practice make permanent!!!!....Perfect practice makes perfect!!!
Chris B.
www.neonjones.com
guitarzan13 is offline   Reply With Quote
Old November 14th, 2007, 03:05 PM   #2 (permalink)
eryque's Avatar
Is that radius a half-circle or quarter circle?
If it's a half circle, it'll only work on small fret wire, otherwise it's fine for standard fret wire. Really big fretwire has a crown a little less than .060", so it might not be big enough to work on 6105's or 6100's.
Old November 14th, 2007, 06:48 PM   #3 (permalink)
Vizcaster's Avatar
Look at Warmoth or Musikraft or USA Custom guitars for a discussion of the various wire sizes, referred to by the Dunlop numbers by those who know, as opposed to "vintage," or "medium-jumbo" or "jumbo."
If you only have one size wire to work on, then a standard crowning file meant for that size is the most foolproof. However, an alternative (still not cheap, but cheaper than multiple files for different wire sizes) is the quarter-round file at Stew Mac, which only cuts one side of the crown at a time. On the one hand, you have twice as much filing to do, but on the other hand you get some control and you only need one file.
