Old October 28th, 2003, 11:34 PM   #1 (permalink)
BrianF's Avatar
Need shielding / grounding help w Tele
I did some experimentation today and rewired my 3 way Tele switch so that position 1 and 2 are normal (i.e. 1. Bridge, 2.Bridge and Neck) but in position 3 I get Bridge and Neck in series in hum-bucking mode. I lose the Neck-only setting which I rarely use anyway.
However...now I notice a very noticeable buzzing noise unless I'm touching the strings or anything conductive on the guitar. Somehow or another, I've introduced more noise and can't track it down.
The control cavity looks like some sort of black conductive paint...but I see no wires attached to it... There are strips of black paint coming up from both ends of the cavity to nearby the wood screw holes where the control plate attaches. I assume this is supposed to make mechanical contact with the plate...but I don't think the shielding is working too well or at all.
Any ideas?
Old October 29th, 2003, 01:58 AM   #2 (permalink)
BrianF's Avatar
update...
the problem seems solved simply by plugging the amp into a different AC outlet in the house...although it is puzzling...
Old October 29th, 2003, 09:26 AM   #3 (permalink)
i think you need to run a ground from the metal cover on the neck pup to the back of the volume pot. There are many post on how to do this, do a search on 4 way switchs and you should come up w/something. As well, you could always take the cover off!!
gottliver is offline   Reply With Quote
Old October 29th, 2003, 10:08 AM   #4 (permalink)
Lyle Caldwell's Avatar
http://www.guitarnuts.com/wiring/menu.html
"Everybody sings about Memphis, but nobody ever does anything about it."
Lyle Caldwell is offline   Reply With Quote
Old October 29th, 2003, 11:31 AM   #5 (permalink)
Re: update...
Brian, you may have some wiring questions to deal with. If one outlet yields noise while another doesn't, there is a good chance that the noisy outlet is miswired. You can get a simple tester at any good hardware supply. Every electic musician should have one handy.
We 'old' players' are familiar with this situation. In the days of two-wire power cords and non-directional plugs, we often had to either utilize the polarity reversal switch if we had one or turn the polug around in the socket to reverse the polarity.
Old October 29th, 2003, 04:12 PM   #6 (permalink)
BrianF's Avatar
the noisy AC outlet is a GFI type outlet...
Not sure if that's significant...but it is different.
Old October 29th, 2003, 05:05 PM   #7 (permalink)
Brian, that is even more reason to go spend a few bucks for a circuit tester. A GFI outlet that is miswired is not only a problem, but it may not function as needed when things go wrong. A tester will tell you if you have an open ground, open neutral, open hot, hot/grd reversed, hot/neutral reverse, or correct wiring. For less than $10 you get a great tool.
vB code is On
Forums Directory
