Old October 15th, 2003, 04:03 AM   #1 (permalink)
hippietim's Avatar
brass saddles and grounding
I put brass saddles on my MIJ Paisley tele and have noticed that it hums worse than before if I'm not touching strings with both hands. If I touch the bridge plate all hum disappears but just touching a couple strings or the brass saddles doesn't help much. Is brass just a bad conductor?
I have a Kinman in the neck position and a little '59 in the bridge so the thing is dead quiet when I get my hands on the right spot on the bridge or enough fingers making contact with the strings.
hippietim is offline   Reply With Quote
Old October 15th, 2003, 05:43 AM   #2 (permalink)
The Snowman's Avatar
hmmmm
I have the same thing in my Tele's Kinman's & Brass saddles....and I don't get any noise at all....maybe a ground wire came loose.....
hey, you can alway join me and play with the cover on....
but that's another topic.....don
it ain't nuttin but the bluez....
The Snowman is offline   Reply With Quote
Old October 15th, 2003, 07:21 AM   #3 (permalink)
blueshawk's Avatar
A bit difficult to understand because...
whilst not the very, very best conductor - it is pretty good, and certainly nowhere near being an insulator (which it would need to be to explain the problem you describe)
Hmmm, puzzling my dear Watson...
Please accept my resignation. I don't care to belong to any club that will have me as a member - Marx (Groucho)
blueshawk is offline   Reply With Quote
Old October 15th, 2003, 08:32 AM   #4 (permalink)
I would think that brass is a good conductor....alot of plugs use brass for the connections....hmmmm
Old October 15th, 2003, 05:36 PM   #5 (permalink)
Loose ground!
Brass is a good conductor. What you are describing sounds like a grounding problem. You can ground the bridge plate with a bare wire lying under it fed through the wiring channel & soldered to either pot.
Andy
Andy B is offline   Reply With Quote
Old October 15th, 2003, 05:39 PM   #6 (permalink)
hippietim's Avatar
Re: Loose ground!
I don't think so. Touching the bridge plate anywhere works fine - just not touching say a single saddle.
Old October 16th, 2003, 12:15 PM   #7 (permalink)
johnnelles's Avatar
Brass is commonly used for audio patch cables - so I think that would qualify it as a pretty good conductor.
johnnelles is offline   Reply With Quote
Old October 16th, 2003, 05:46 PM   #8 (permalink)
Very Strange!
Did you do anything else at the same time as you changed the saddles? I'm thinking a pinched wire if either the bridge or control plate was lifted. The only other question I have is: Are the saddles coated with epoxy or paint which would act as an insulator?
Andy
Old October 16th, 2003, 05:54 PM   #9 (permalink)
hhhhhhmmmmmmmmmmmmm ?
Tim....what are the screws made of on the saddles....maybe that's where the ground problem lies....weird but this has me going nuts......don
Old October 29th, 2003, 06:34 AM   #10 (permalink)
Tele Bridge Ferrous or non ferrous?
Anyone have a view whether the correct original pre 65 tele bridges were made of ferrous or non ferrous metal.
I'm told later ones are made of Cheaper tin pot that seriously affects tone...
Spranglicious.
spranglicious is offline   Reply With Quote
vB code is On
Forums Directory
