Old September 28th, 2006, 04:42 PM   #1 (permalink)
Flashback's Avatar
Flat Colors and Flat Clear Coats
Ok I am in the process of painting two guitars, one is done. The other is a Squier 51 project that I am painting flat black primer and hoping to add a flat clear coat. I am wondering what kindof sanding processes should I do to the flat clear coat. Cause I dont want any shine just a nice flat coat to protect the original primer. Any suggestions?
Flashback is offline   Reply With Quote
Old September 28th, 2006, 05:16 PM   #2 (permalink)
al heeley's Avatar
Are you painting or spraying? You'll end up with brush marks or some orange peel surface either way which will need sanding out. Sanding out = flattening the surface = gloss. You can then get hold of a matt varnish (commonly it has some fumed silica in which gives a micro-dimpled surface = no gloss) or you can rub down with fine wire wool and a scotchbrite finishing pad. This will take the flat surface off and give a silk or matt finish. Not really dead matt but not too shiney. Best thing is to try it out first on some waste wood pieces.
al heeley is offline   Reply With Quote
Old September 28th, 2006, 05:43 PM   #3 (permalink)
jwells393's Avatar
If you have a good spray technique, get yourself some Deft Satin for your clear coat. If you're good with a spray can and have a dust free area to work in you should be able to get a nice finish with no sanding. If you do any wet sanding I wouldn't go above 1000 grit. If you go any finer it's going to begin to shine.
