Strings Move On Saddles
I've noticed that the strings move around on the compensated brass saddles of a Partscaster that I built.
I look down and the string spacing is closer between some strings . . . mainly the first three . . . Of course I just lightly squeeze one or the other to visually put them back to even spacing. Is this normal? If not . . . what's the cure? File a small groove for them? |
#2 (permalink) | |
Do your saddles' intonation adjustment screws all sit fairly parallel to each other, or does it have any alignment/fit issues causing them to sit splayed out? When the strings are spaced how you like them, are the strings relatively straight end-to-end? Yes, filing a small groove can help. But it would be worthwhile first making sure your Tele doesn't have some other issues with alignment or fit. With Stewmac brass comp saddles, I had to grind/cut some material off the inside ends to get them to align and fit together properly. Here was a set I had shaped that way: ![]() I have used a small file and sometimes a Dremel cutting wheel (very carefully) to make grooves in them. The Dremel wheel I used to get a starting notch, the file I used to shape and smooth it. I think the set in the pic above, I hadn't grooved yet.
#3 (permalink) | ||||
I figure I can align the strings on the saddles . . . get an eraseable magic marker . . . mark right on top of the strings at the saddle with the marker, which should leave me a clean area where the string was to cut once the string is away. |
Vince a,
The Callahams seem to be made short enough they shouldn't have the fit issues I had with the Stewmacs, so they should be able to sit correctly keeping the strings straight and without taking material off the inner ends. The marker idea is what I've done too. U sed a fine point permanent marker (Sharpie) and mark on either side of each string. You don't need to make it long, just a very short groove centered longitudinally where the strings now are making contact. Shorter than the length they cover now is better than the full length. It doesn't need to be erasable marker, the permanent stuff will clean off quite easily with solvent, fine sandpaper, steel wool or polish. |
