wiring: series / parallel
My mind gets tied in nots when I try to think about this. So, can someone help me here? Is it possible to wire a 3-pickup setup in this configuration, and if so, how do you do it? thanks fellas!
position: (1) bridge (2) bridge & middle (3) bridge & neck parallel (4) bridge & neck series (5) neck or I'd even settle for this: (1) bridge (2) bridge & middle (3) middle (4) bridge & neck series (5) neck
I usually don't do requests, unless somebody asks for them... |
Yes, but no... but, yes.
Just to be clear...
The series and parallel combos you want can not be achieved with a standard (two-pole) 5-way. Your options are described (if briefly) in the above posts: #1, you can use a push/pull to add some series combos to the standard Strat combos (I have some drawings) #2, you can use a four-pole SuperSwitch, replacing your standard 5-way, and pick just about any FIVE pup combos you can think of ( I can create a drawing)
YMMV - I been wrong before... |
thanks
ok,
thanks everyone. I put in a 5-way super and wired it up. I'll use the 2-pole 5-way for my strat.
I have a wiring diagram for a Super Switch which I've used on several 3 PU Jerry Jones guitars. It gives you:
neck/neck+bridge series/middle/middle+bridge series/bridge It works great with lipstick PUs. It should work with regular Strat style PUs as well. jwhanor at mindspring.com |
middle-bridge
Hey phat Tele,
how is that bridge-middle series in comparison to the bridge-neck series? I never thought of having that combination before.
