Old July 19th, 2003, 02:35 AM   #1 (permalink)
pickup height
ive been wondering about pickup heights on my tele lately. my bridge pickup has been giving off really sharp and loud feedback whenever i have some good crunch. my grandfather who owned the guitar previously said to take a little screwdriver and lower the pickup a little bit (bridge pickup of course) i was wondering if i do go about lowering my pickups how would i go about measureing it? are there any other effective ways to reduce feedback for the bridge pickup?
any help is greatly appriciated
Wheelman_69 is offline   Reply With Quote
Old July 19th, 2003, 06:58 AM   #2 (permalink)
rebelern's Avatar
Just click on---
www.mrgearhead.net
then Fender,and Pickups, then check out all the rest!.
Welcome to TDPRI.
Ernie.
rebelern is offline   Reply With Quote
Old July 22nd, 2003, 09:55 PM   #3 (permalink)
Kurt's Avatar
You can start with the Bill Lawrence method
Try placing two nickels between pickup and strings on the bass side and one nickel on the treble side. You can use this as a starting point and then dial in exactly what you want from there. On my Tele, using Bardens, it took quite a while to balance the pickup height and the tone from my amp. But it's worth it to take the time and get it just right. Good luck.
Kurt is offline   Reply With Quote
Old July 25th, 2003, 07:34 PM   #4 (permalink)
so you would know that the pickups were balanced right if the feedback has lowered and your tone sounds correct
Old July 25th, 2003, 08:32 PM   #5 (permalink)
Matt Plescher's Avatar
that's what I do - just listen. Some like the pickups high, some low. Generally having them high can cause problems like wolftones, but I'm one who likes the sound of them kind of high. Like all guitar setup there is starting point measurement, and then fine tune by ear and feel from there.
As far as feedback that could be microphonics- the bridge pickup needs to be very tight and secure in the bridge plate. Maybe a loose baseplate on the pickup.
I'm no expert on the feedback problem though, someone correct me if need be.
Cheers
Matt
She's not your satellite
She doesn't miss you
So turn off your smoke machine
And Marshall stack
Matt Plescher is offline   Reply With Quote
Old July 25th, 2003, 09:28 PM   #6 (permalink)
TeleTubby's Avatar
Matt could be correct with his comment about the feedback. If it happens more the higher the gain goes, it's more than likely the baseplate of the pickup, the front edge of the bridge itself, the windings of the pickup, or sometimes even the springs on the pickup mounting screws. I had one Tele that started feeding back and I would just put a little pressure on the front lip of the bridge to stop it- not a very convenient way to play There are many cures if any of these thoughts turn out to be the problem- check'em out and let us know what you find.
TeleTubby is offline   Reply With Quote
