Where Can I Get Nut Files?
I know I can get them from Stew Mac, but they seem a bit expensive. Wamoth sells them, but they sell them as a package, and I'd rather be able to pick and choose. Shipping and handling at both of these places is $8.50. MAN that's high! Any other places I can purchase nut files? Thanks!
Nut file(s)
An alternative from Stewmac would be the diamond file. I have used it to do the whole shebang. I prefer using proper guage files of course, but if you have to you can do the whole thing with that. You just cannot have the slots very deep.
http://www.stewmac.com/cgi-bin/hazel...files&sku=4410
Psalm 33:3 - Play skillfully as you shout out your praises to Him! |
I use single gauge, flat, edge radiused nut files. I have about 16 or 18 of them in various gauges for working on everything from mandolins to electric basses. They're mostly fair priced - haven't seen any bargain priced ones for sale. I wouldn't even consider using a file that didn't have a proper edge radius. Nor would I use a tapered edge file, since that also distorts the slot bottom and sides.
Aside from making a buck, I don't understand how a company like Stew-Mac (and others) can peddle inappropriate "nut files" like the diamond nut file that cuts a "V" rather than a pefect radius "U" nut slot. Nut files MUST be flat sided (parallel, not tapered) and the cutting edge MUST be properly gauged (radiused). Anything else, IMO, will not cut a proper nut slot. YMMV. |
I agree with Rob. I too use the proper radius (thickness) file for each slot. You can fudge a bit and use a thinner one for a slightly wider slot so you don't HAVE to have more than about four or five if your just using them on one type instrument. I suggest you go ahead and bite the bullet and get the right stuff in the first place and don't try to shortcut. This is a hard enough job already even with the proper tools!!!
steve |
Yes, you absolutely can - and IMO, should - fudge on the nut file gauge size usage.
For example, a .013" file can easily handle strings from .009" thru .014". Rolling the file from side to side as you cut the slot will open up the slot width, and using a larger file size for a smaller string diameter is perfectly acceptable. |
Warmoth
I ordered the 8 piece set from Warmoth for $64 -- about half of Stewart MacDonald's price.
http://www.warmoth.com/common/supplies/Files.htm |
