Old February 3rd, 2005, 06:59 AM   #1 (permalink)
el_extranjero's Avatar
Which pickup for home-brew Esquire?
After reading all about the new Fender Esquire I decided to build an Esquire control set for my MIM Std. Anyone have recommendations on a pickup? I have the pickup off my MIM std (2002), my Vintage Noiseless that is currently in my Tele and sounds great, or a 52RI I just purchased off eBay.
I had also considered the SD52 or Quarter Pounder. Since it is the ONLY pickup, it is very important! Plus, since one of the primary positions is wide open, it has to be well balanced (hence the SD52).
Any recommendations and experience to share?
Thanks
El Extranjero de la Tierra Extraña
Dorothy: "How can you talk if you haven't got a brain?"
Scarecrow: "I don't know. But some people without brains do an awful lot of talking, don't they?"
el_extranjero is offline   Reply With Quote
Old February 3rd, 2005, 07:42 AM   #2 (permalink)
tjalla's Avatar
Having tried the following...
Fender 52RI
Antiquity Flatpole
Rio Muy Grande
Harmonic Design S90
Lollar Special
Peter Florance Voodoo
Fralin Vintage wind
Fender Texas Special
I'd definitely lean toward something with more output and mids (esp once you hit that "wide open" position).
From the above, the Lollar would be my pick. The antiquity would be good for a more traditional sound, and the S90 the best choice for a rockin' esquire.
That said, I've a sneaking suspicion that the Duncan Donahue would make a great esquire pup. As might a Hamel...
tjalla is offline   Reply With Quote
Old February 3rd, 2005, 10:00 AM   #3 (permalink)
Captain Simian's Avatar
What about a DiMarzio Twang King? I love that pickup.
If you're looking for trouble, I've got the map!
Captain Simian is offline   Reply With Quote
Old February 3rd, 2005, 02:39 PM   #4 (permalink)
Raymond's Avatar
You'll need a pickup with a lot of output as tjalla says. My personal preference would be a BL L-290TL-E. For $48 bucks you just can't loose and it's a great pickup specially designed for Esquires.
Another great option is the Duncan Broadcaster ($60). Our own genius luthier (he he… he'll hate me for this) Kevin uses it in his personal Esquire and he can't be happier. You can't go wrong using what Kevin uses.LINK
"That's a hard pill to swallow, buddy; when you find out what the blues is all about"
Raymond is offline   Reply With Quote
Old February 3rd, 2005, 02:50 PM   #5 (permalink)
BB
BB's Avatar
Re: Having tried the following...
Originally Posted by tjalla
Fender 52RI
Antiquity Flatpole
Rio Muy Grande
Harmonic Design S90
Lollar Special
Fralin Vintage wind
What Trevor said. I'd also add the wonderful SK-T-90 to the list. If it came down to one though, the Lollar would also be my #1 pick.
BB is offline   Reply With Quote
Old February 3rd, 2005, 03:59 PM   #6 (permalink)
fezz parka's Avatar
I put a Duncan STL-2T in mine. Wired it ala the '53 tele. Position 1 is hot, 2 is tapped, 3 is tapped going through a PIO .015 Gudeman cap. Extremely versatile for a 1 pickup guitar...
Old February 4th, 2005, 10:24 AM   #7 (permalink)
Poppatwang's Avatar
Suspicion confirmed.
SD Jerry Donahue makes a great Esquire pup.
Use a B'caster in my Tele. Wanted something
more aggressive for the Esquire. The JD did it.
The Dieselfitters
http://www.dieselfitters.com
Roy Hubbs
http://www.royhubbs.com
Poppatwang is offline   Reply With Quote
Old February 6th, 2005, 04:47 PM   #8 (permalink)
Bill Ashton's Avatar
I have an SD Vintage Lead Stack
in mine and its quiet but great.
Actually you would be amazed at how good the MIM Standard Tele p'up sounds in there all by itself. When I was building mine and had a lead...uh...malfunction...I put one in just to get the ax usable again...didn't take it out until I got (with new leads) my SD back from SD...and I almost didn't take it out!
Bill Ashton is offline   Reply With Quote
Old February 6th, 2005, 08:25 PM   #9 (permalink)
johnnylipps's Avatar
ditto on the Twang King
When I got my MIM in 2002, I found I was using the bridge pickup more than the neck and decided to convert the Tele to an Esquire, using the wiring diagrams off Seymour Duncan's site. After a lot of shopping around and reading I settled on the Twang King and have been very happy. I find that I can get a nice range of sounds just by riding the tone pot and keeping the volume back a bit for rhythm then opening it up for leads.
Everything has been changed on this guitar (now it has a HW1 body, Warmoth boatneck with graptech nut, Wilkinson bridge and compensated saddles, Hipshot b and g benders, reversed the control plate early on, and of course an Esquire pickgaurd), but the Twang King has remained and I'm still happy with it.
johnnylipps is offline   Reply With Quote
