fundraiser
Old October 18th, 2004, 02:24 PM   #1 (permalink)
Vince a's Avatar
Mount Pickups W/O Screws???
OK . . . I did a search, and d/n get the answer I needed.
I have an 2003. A/S. Someone "gave me" - they really did - a single ply pickguard, 5-screw mount, but w/o the screw holes to mount the neck pup.
I want to swap to this p/gd.
So, how the heck do you mount that pup and how do you make any needed adjustments???
I know I could figure it out, but you guys are so damned good, I know someone will save me the time???
Thanks in advance,
Vince
Vince a is offline   Reply With Quote
Old October 18th, 2004, 02:55 PM   #2 (permalink)
gtrwrks's Avatar
guards without the pup mount screw holes still use screws to mount the pickup. the screws may be different than those used to mount to a pickguard are. usually they are a 'self-tapping' wood screw. the pickup height adjust is made (somewhat inconvieniently) by taking the 'guard off, adjusting the height (adjusting the screws up and/or down) then replacing the 'guard. sometimes this type/style of mounting will use springs between the bottom of the pup and sometimes a dense foam will be used (like with p-bass and j-bass pickups). either is effective, but springs tend to be a little more helpful/adjustable.
hope this helps.
www.myspace.com/toddlynchmusic
gtrwrks is offline   Reply With Quote
