Old November 21st, 2009, 05:01 AM   #1 (permalink)
fordfanjpn's Avatar
Removing old jack
I want to replace the old jack cup on one of my Tele's with an Electrosocket. Is there a trick to removing that piece of metal inside the jack hole without using some kind of special tool?
Bill
fordfanjpn is offline   Reply With Quote
Old November 21st, 2009, 05:43 AM   #2 (permalink)
I Just left that clip in when I switched to an electrosocket.
tjk3052 is offline   Reply With Quote
Old November 21st, 2009, 02:21 PM   #3 (permalink)
Guitarmadcat's Avatar
Using a pair of snipe nose pliers, grip one end of the clip through the hole and bend away from the direction the claw digs in, pushing it into the guitar and let it fall out.
I don't recommend leaving it in, in case it falls out later and shorts something.
Guitarmadcat is offline   Reply With Quote
Old November 21st, 2009, 03:59 PM   #4 (permalink)
VENDOR
mellecaster's Avatar
Would Love to see how that worked out ??
Contact Info
Old November 21st, 2009, 04:17 PM   #5 (permalink)
Mightyaxeman's Avatar
I push them into the control area with a big screwdriver.
Mightyaxeman is offline   Reply With Quote
Old November 21st, 2009, 04:34 PM   #6 (permalink)
fordfanjpn's Avatar
Thanks guys. For some reason pushing it in never occurred to me. I'll give that a try.
Bill
Old November 21st, 2009, 08:30 PM   #7 (permalink)
indiobravo's Avatar
yeah, be careful - for some reason i felt it had to come out (as opposed to pushed in), and i chipped my finish around the perimeter. luckily i was at least smart enough to try this on a lower-end tele the first time and i learned my lesson, but it was a totally unnecessary lesson ;-)
grrrrrrr! stupid is as stupid does
done, for better of for worse
indiobravo is offline   Reply With Quote
Old November 25th, 2009, 02:56 PM   #8 (permalink)
Imput Jack ?? I have a 56 master built tele. The imput jack seems real tight . is this normal?
lray56tele is offline   Reply With Quote
Old November 25th, 2009, 03:29 PM   #9 (permalink)
Not sure what an imput jack is. Every tele I've ever seen has an output.
Tight jacks are fine. This usually just means that the part of the jack that presses into the dent on the tip of the cable has a nice strong spring to it.
LocustPlague is online now   Reply With Quote
Classic Cars - Front End Jack vs Rear End Jack Eric Karonen Bad Dog Cafe 6 March 26th, 2009 01:11 PM
Help removing tele jack/cup TNO Tele-Tech 1 November 16th, 2008 07:52 PM
Removing a nut? martyb1 Bad Dog Cafe 1 July 26th, 2007 08:20 PM
REmoving and re-installing a jack and cup halfmassive Tele-Tech 1 July 31st, 2006 06:56 PM
removing nut Meltinpix Telecaster Discussion Forum 1 June 24th, 2004 03:43 PM
