Old November 20th, 2009, 01:08 PM   #1 (permalink)
52 wiring scheme
"The '52 wiring has a bassy rhythm tone in the first position of the switch. The middle position is neck pickup only, the third is bridge only. The main difference between the '52 and the '66 is that the 1966 style allows for combination of neck and bridge pickup together in the middle position."
Anybody use the 52 scheme?
Your thoughts?
thessandman is offline   Reply With Quote
Old November 20th, 2009, 01:27 PM   #2 (permalink)
sjtalon's Avatar
Most don't like the dark neck and miss the distinctive N&B so wire std. (for nowadays) Tele.
No caps on the switch
Pos. 1 Bridge
2 N&B
3 Neck
and then use the tone pot if you need a little bass.
Old November 20th, 2009, 02:19 PM   #3 (permalink)
Thanks, I was wondering if anyone liked the dark neck.
Anybody else?
Will this wiring scheme work? tantamo Stratocaster Discussion Forum 3 May 14th, 2009 01:34 AM
Is this wiring scheme possible ? fletch Stratocaster Discussion Forum 0 September 15th, 2008 03:58 AM
4 way wiring scheme.. moonshiner Tele-Tech 1 January 27th, 2006 06:01 PM
Need crazy wiring scheme help..... heylow Tele-Tech 10 September 24th, 2005 03:01 PM
Anybody else use this wiring scheme? skiraly017 Stratocaster Discussion Forum 9 April 17th, 2003 01:26 PM
