what about EDEN body's
hello fellow expert
im looking at an add on this forum for a white F hole body look's nice and could be a project I would like to start.but I no very little about the manufacturer EDEN is the maker of this body the owner state's it weight about 4lbs.at the right price would it make a good foundation for a project.or should I skip this item again thank you for the help Daniel |
I've only had one, A white solid body.
The body fit one of their necks nicely, but a Fender spaced neck plate doesn't line up. I ran into another problem later that the bridge route and string thru holes were like3/8" or something too far from the neck pocket to intonate correctly. Aside from having those issues to fix, it was lightweight, and finished well. (white, how bad could it be?) |
I have an Eden neck and it is mostly fine but rough in details. The tuner holes have been drilled by somebody free-hand, obviously as an afterthought, and they are fizzled out.
The truss rod screw looks like it's in a funny position but IIRC it's functional. For Tele bodies I have seen cheap American offers on ebay just today, that's where I'd go first. Note that even if the neck pocket is tight as delivered, if the wood is insufficiently aged it will shrink and you'll end up with a loose neck pocket anyway. |
I have a partscaster with an eden thinline body,mighty mite neck and Keystone pickups.
The Eden body is light weight and very resonant and was well finished.It was not drilled for string through body bridge nor for neck mounting. I chose a Wilkinson bridge that allows string through or top loading and made it a top loader. I had the neck and bridge mounting done by a tech as I do not have access to a drill press.That was a smart move and inexpensive. I mounted the neck pickup with a chromed surround plate and avoided a pickguard altogether. The guitar sounds great and I attribute some of that to the Resonant Eden body. |
| Getting SPAMed by Eden & Eden [rant] | robt57 | Bad Dog Cafe | 8 | January 25th, 2009 01:03 PM |
| What it is it with Eden | Gary in Boston | Tele-Tech | 45 | April 18th, 2008 09:04 AM |
| Eden | Gary in Boston | Tele-Tech | 1 | March 15th, 2008 09:23 AM |
| Is there bigger PG's (closer to the body's edge)? | simon | Telecaster Discussion Forum | 0 | July 27th, 2004 06:17 AM |
