Volume difference between strings
I bought a Fender Telecaster MIJ 62' reissued with Texas Specials.
When I tried the tele on a Fender Frontman it sounded really good, but when I tried it at home on a gnx4 on a PA. I heard a real noticable volume diffrence between the strings: E - loud A - normal D - soft G - soft B - soft/normal e - normal I called a local guitar dealer and he told me it was because the fretboard has a round shape and my pickups are flat. But when I see videos of people playing the same guitar as me I don't notice the volume difference. My question is: Is it because of the round shape of my fretboard or is there something else wrong with the guitar, and how do I fix it? |
VENDOR
It's because the magnets are set at one height and not adjustable on single coil pickups. But that's all going to change real soon. (hint hint)
If you set the pickups lower from the strings, it will even out a little. If you're playing with a lot of distortion or gain, it won't be nearly as noticable as when you're playing with a very clean sound. |
It's indeed not normal, the plain G and B should be the loudest ones. What string gauge do you play? Maybe it's that GNX4. Can you try it through another real guitar amp?
Also, do you have something with a peak meter/indicator? Or any hardware or software will do, tuners or DAWs, etc. where you can see volume. Then pick the strings one by one with equal force and you'll see if any of them are really louder or only you hear it that way. |
One thing I'd do is start to mess with the tilt a bit...if you're low E is booming hard, lower the pickup on that side a bit (or raise up the high e). I'm sure there's a scientific way to deal with pickup height, but for me it's pure vodoo. It can make all the difference in the world when you find the sweetspot. You can also mess with string guages a bit see if it helps.
You could also have a bad log...I had a highway one strat body that was a really dense alder. There were absolutely no mids in that guitar at all...freaked me the hell out. Put the pickups into a different axe and everything changed. Turned out it was just a crappy piece of wood. Same setup (neck, bridge, pickups etc.) sound amazing and balanced with a better body. |
I also have the same problem with my home-built tele. The neck is from mighty mite and body is alder, plays through a vox valvetronix. First it was the huge difference between neck and bridge pups, the bridge had rails. It sorted out with a little bit of hight adjustment to the rails (i guess theyre more sensitive to hight than regular pups) but now i have the volume difference between strings, at least thats what my friend says. I gave the guitar to him as i cant play these days. The problem is mainly on the G string (maybe even B and D too) only noticeable when playing around 15th fret closer to the end.
went out to try out some american teles the other day to check if some had a similar problem but they were all well balanced. Its nothing you can realise right away but when you play everyday it bugs you. Still couldn't figure out whats wrong... i suppose my neck pup is causing the problem as its more obvious when playing neck only, maybe the magnet hights in the pup are not properly aligned like a production defect, or it might well be the wood or the pups natural characteristics. im going to try measuring with the peak meter once i get the guitar back, havent thought about that before ... |
Are the saddles set to the correct height/radius?
Have you changed the strings yet? You should always change the strings when you get a guitar.
Why didn't the Psychic Network already know I was gonna call?
Get a compressor and learn to use it. It will even out the string volume.
Mike The only thing nescessary for evil to thrive is for good men to do nothing. Last edited by gitlvr; November 5th, 2009 at 08:49 AM. Reason: spelling |
I have a strange similar problem in my Tele.
The G string always sounded too loud. 10-16 radius neck. Flat poles bridge pup. Earvana nut. Glendale brass saddles, but it also was too loud with the Gotoh modern bridge that it had before. (and the D too soft, wich I think is usual) Anyhow I think it's important to pay attention to the decay of each string to determine if it's a problem on the bridge saddle or at the nut, not letting the string develop it's sound freely. If the string does not only sound soft but it decays faster than the other maybe it's a problem in the saddle or nut (I'm speculating, but I thing it may be related in some cases) |
VENDOR
Again I will state....If it sounded Great played thru the Frontman Amp, why do you feel it's a problem with the Guitar ??
Perhaps I'm missing something Obvious ?
True, but Mellecaster has a good point, and if/when the OP checks back in to this thread, he'd be well advised to consider that. I've used amps and processors/modellers like the GNX4 the OP mentions. IME, the processors that are basically just multifx units with no preamps in them can sound great, but the ones with the built-in pres can have problems like he descibes, as well as a host of others. I can almost always get an "acceptable" tone out of them, but nothing close to what I can get plugged straight into a half decent amp with a few pedals for effects as needed, IME. I used a preamp/processor for years with a power amp and thought my tone was good. Then I plugged into an amp and never looked back.
Mike The only thing nescessary for evil to thrive is for good men to do nothing. Last edited by gitlvr; November 5th, 2009 at 11:52 AM. Reason: spll |
#16 (permalink) | |
VENDOR
#17 (permalink) |
I've seen this problem. I spun the tone pots on the amp around and the problem went away (miracle). Someone busted me - I had the gain and volume dimed with the Mid pot at (0) when I had the uneven string volume.
GS |
| Man, strings make such a difference! | giantslayer | Acoustic Heaven | 26 | January 28th, 2009 06:31 PM |
| Difference between DR Strings | g00dbye | Telecaster Discussion Forum | 16 | July 1st, 2008 11:44 PM |
| Pickup Volume Difference | drmathprog | Telecaster Discussion Forum | 7 | December 13th, 2007 11:58 AM |
| Strings, do they make a difference? | mdunn | Tele-Tech | 17 | January 22nd, 2007 06:04 AM |
| volume pot...what's the difference?? | schmee | Tele-Tech | 5 | May 19th, 2004 02:16 PM |
