Old October 31st, 2009, 10:00 AM   #1 (permalink)
12 String Tele/Strat Partscaster questions
I'm getting close to finishing my first partscaster....body prep, paint and clear and then slap 'er together.
I'm giving thought to a second project, not sure if it'll come to fruition, but here's my thoughts so far:
1) Either a Tele or Strat thinline style body...not sure which manufacturer yet
2) Looks like Warmoth has 12 string necks/nuts...more research needed though
3) Tuners, misc hardware, pick guard and electronics shouldn't be a problem
4) from what I can tell, standard 6 pole pick-ups can be used
I'm stuck when it comes to a bridge & saddles....what's available out there? Does it make sense to consider a Strat style hardtail bridge? Am I missing out on anything?
I want to keep the costs reasonable....
Toughts? Suggestions? Ideas? Photos?
Thanks
Tom
tcarp is offline   Reply With Quote
Old October 31st, 2009, 03:56 PM   #2 (permalink)
Hi Tom,
Here is a double neck partscaster that has a 12 string on the bottom. I am using the Gotoh 6 and 12 string bridge for this project. I know others have used this too, as well as taking the parts off the 12 string Gotoh bridge and mounting them to a standard tele type bridge. I was going to go this route, but decided to stay with the standard Gotoh.
Hope that helps....
Jett is offline   Reply With Quote
Old October 31st, 2009, 03:57 PM   #3 (permalink)
I am doing a chambered strat Baritone and a 12 string tele or jazzmaster
for the neck you can also get a 12string at USCG which has a more Fender headstock design, its between the hockey stick and the plain Warmoth. Gotoh make a 12 string bridge. its a combination of string through the body and stringing through the bridge. I have seen the Gotoh saddles adapted to a tele bridge. The pickups i am going for are either lipsticks or G&L Z design.
Heres a mock up of my Baritone chambered strat.
tonyw is offline   Reply With Quote
Old November 1st, 2009, 10:32 AM   #4 (permalink)
rhomco's Avatar
Go for it!
I build Tele 12's for friends on occasion. The Warmoth 12 string neck is very nice but a bit wide at the nut for most players. Better to get a paddlehead tele neck you like and cut/drill/finish the headstock yourself. You can use the stock Gotoh 12 string bridge as is without the ashtray look and it works nicely but I hear a difference in the bridge pickup tone without the steel baseplate. I prefer to use the Gotoh intonatable saddles on a modified ashtray or am std type bridge. Here are a few I have done like you mentioned.
Rob
If I won the Lotto.... I'd just build (OK, OK Assemble) guitars and sell them till the money ran out
rhomco is online now   Reply With Quote
Questions for a '72 RI Tele Custom "Partscaster" absurdplanet Telecaster Discussion Forum 1 June 12th, 2009 01:54 PM
12 string tele questions.........and pics of yours! evol04gt Telecaster Discussion Forum 15 October 14th, 2008 10:31 AM
Can I use a 5-way Strat switch in my Tele partscaster? funff Tele-Tech 9 February 12th, 2008 05:36 PM
'Mary Kaye' tele partscaster and Strat twin Hendrixaxe66 Tele-Tech 2 December 28th, 2006 06:00 AM
Partscaster Tele, or Real Strat...need some advice.... TheGoodTexan Bad Dog Cafe 11 September 20th, 2006 10:39 AM
