Old October 29th, 2009, 02:21 AM   #1 (permalink)
esquire wiring question
hi....i want to change a fender esquire harness so that the third position switch setting produces a tone that is about 1/3 or 1/2 as bassy as the normal muddy bass-like sound.....if i change the value of that 3.3 k resistor will this do something like i am talking about..?...thanks
eddie echo is offline   Reply With Quote
Old October 29th, 2009, 02:34 AM   #2 (permalink)
Mark Davis's Avatar
Yes you can do that or install a mini pot and adjust it anyway you please.
Here is the schematic.
You can also use a push pull pot.
Old October 29th, 2009, 02:50 AM   #3 (permalink)
thanks...that looks handy....although i dont know where i'd put a mini pot.....i have ...poor tech skills...but i can solder....,
Old October 29th, 2009, 03:47 AM   #4 (permalink)
Mark Davis's Avatar
What you do is wire it all up and turn the mini pot to where you like the fixed bassy sound and duct tape it up and just put it in the control panel area.
You can also glue another pot upside down to the vol pot and do the same thing.
Or you could drill an extra hole in the control panel and mount the mini pot and use a small knob to adjust it there are lots of ways to skin this cat.
Probably the simplest way is just get a handfull of resistors and try them till you find the ones you like resistors are cheap.
I think Fender used 3.3k and 2.5k resistors in the Esquires.
Old October 30th, 2009, 01:27 PM   #5 (permalink)
just commenting so I can find this thread easily later on - love the minipot idea!
All this would be a lot more simple if we played bass.
cowie86 is offline   Reply With Quote
Esquire wiring question GopherTele Tele-Tech 1 September 25th, 2009 10:09 PM
4-Way Esquire wiring question newtwanger Tele-Tech 0 October 30th, 2008 12:24 PM
Esquire wiring question: 3.3K resistor? vendo Telecaster Discussion Forum 4 January 13th, 2007 03:50 PM
Esquire wiring question appar111 Tele-Tech 7 December 8th, 2006 04:46 PM
Another Esquire wiring question tonfarbe Tele-Tech 6 April 12th, 2005 04:37 AM
